P0036 2007 G6 V6 help!! - Pontiac G6 Forum
post #1 of 11 (permalink) Old 11-15-2011, 04:52 PM Thread Starter
i have a 2007 pontiac G6, V6 - 3.5L
keep Pulling code P0036
I know its an 02 sensor, but don't know where it is...
If someone could give me semi detailed info about what 02 sensor it is, and the easyest way to get at it/replace it, i would very much appreicate it...
Also i know there is a few 02 sensors, should i be fine just replaceing them as they go out, or should i just do them all at once?
THANKS A TON!
Dan
djinferno is offline
post #2 of 11 (permalink) Old 11-15-2011, 05:12 PM
Varsity Squad
CalsGTP's Avatar
P0036 is bank 1 sensor 2, so that is the sensor after the cat to the rear half of the motor (the bank with cyl #1 is bank 1 and sensor 2 post cat sensor) Some manufacturers have a scheduled maintenance to replace, but I would just replace as they go. That is what I am doing. I had the same sensor go. Get it from GM they are reasonable and direct fit.
CalsGTP is offline
post #3 of 11 (permalink) Old 11-15-2011, 07:31 PM
pm me with an email addy & I'll send you the how-to from the GMSI. Its also covered with photos in the Chiltons for G6.
post #4 of 11 (permalink) Old 11-16-2011, 09:47 AM
Metalhead852's Avatar
At least you do t have to rush with it being post cat
Sent from my Autoguide iPhone app
Lima... where the men outnumber the women and the women outweigh the men.
Metalhead852 is offline
post #5 of 11 (permalink) Old 11-20-2011, 10:17 AM Thread Starter
is there any thing i can do to test that it is actually the O2 sensor? i was reading something about swaping sensors and seeing if it throws a different code... if that seems like a good idea can i get some more info about swaping this one? and what one to swap it to... i've got decent mechanical abilitys, just don't know where i should be looking...
post #6 of 11 (permalink) Old 11-20-2011, 01:18 PM
Without a tech 2 the swap test will work. Depending on your mileage, there's about a 99% probability that the sensor/wire harness assy itself is bad. Its a very hostile environment for an electrical circuit.
there's a lot of useful info on youtube:
http://www.youtube.com/user/AutoRepa.../0/XQ9vtD_ssjg
post #7 of 11 (permalink) Old 11-21-2011, 09:36 AM Thread Starter
Just shy of 130,000 and i live in minnesota so its deffinitly a harsh enviornment.... thanks for the youtube link!!
post #8 of 11 (permalink) Old 11-21-2011, 07:39 PM
Actually, I was referring to life in the exhaust pipe. FWIW, the last sensor I got was under 35 bucks at Amazon. At 130K I would just replace them all as they are due & you'll improve your mpg (as their switching gets lazy with age). Just a suggestion.
post #9 of 11 (permalink) Old 12-03-2011, 11:54 AM Thread Starter
Is this the one by my oil filter twards the front of my car? 3.5 l V6 2007
Ifnot a little help on where its by?
post #10 of 11 (permalink) Old 12-03-2011, 01:02 PM
Is this the one by my oil filter towards the front of my car? 3.5 l V6 2007
If not a little help on where its by?
If you PM me with an email address & I'll send you the how-to from the GMSI.
post #11 of 11 (permalink) Old 12-04-2011, 07:59 AM Thread Starter
Its bonafidehustlers(at)gmail(dot)com
Also, i seen i have a p0141 code when i went to clear codes after replaceing the one by my oil filter...
will a 2.4l from g6 fit in a g5 both 2007 mitrani Powertrain Performance Modifications 1 01-27-2011 07:57 PM
My 2007 G6 gsu_golfer Members' Rides 2 06-15-2009 05:37 PM
My 2007 GT jamestg6gt07 Members' Rides 49 06-05-2009 07:06 AM
My 2007 GTP G6 ;D Daze007 Members' Rides 8 02-24-2009 10:28 PM
2007 G6 Bse dencomfort New Member Introductions 1 02-07-2008 10:58 PM
