2008 pontiac g6 sedan headlights issue - Pontiac G6 Forum
post #1 of 16 (permalink) Old 01-03-2012, 07:31 PM Thread Starter
Hey guys I'm new to this website and maybe the answer to my question has already been answered, but I haven't found it yet, if so, sorry for repeating it. I currently have a 2008 pontiac g6 gt sedan. My headlights keep going out(low beam, not high beam), I checked the fuses, and the fuses are good (headlight lowbeam fuses), and i replaced the headlights already. The first time they lasted about a day and then boom one goes out, then the next one goes out. this time, i replaced them and only one worked, and the other one never turned on. I have 3 fuse boxes as you all know, trunk passenger side and under the hood. What other fuses would I have to check besides the headlight low beam fuses? What can be the issue? I took it to an electrician and he checked wiring, and voltage to it ,and he said everything was fine. What can be the issue? or what is the issue? Thanks guys.
killajayy88 is offline
post #2 of 16 (permalink) Old 01-04-2012, 10:07 AM
I had the same problem on my 2009. I would change the bulb and then a couple days later, it went out. I got stopped for it twice! First time, the guy let me go with a warning. I changed it, then a few days later I was coming home late and a female officer stopped me and I showed her the receipt saying I had it replaced by a technician (I changed it once and was too lazy to change it again...lol). But she gave me a fix-it ticket. So, I had to take it to the dealership and they said I was using cheap lights, but then also, they found a wire that was in bad shape, causing the bulb to go out all the time. Unfortunately, it wasn't under the warranty so it cost me almost $500 bucks to have this fixed. But, the reason I brought this up is because this isn't the first time where the headlights have gone out on me. It wasn't the bulb or a fuse, it was the electrical wiring...
calisjoker is offline
post #3 of 16 (permalink) Old 01-04-2012, 10:45 AM
This would've been my first guess anyways. One of the wires is exposed and the cars vibrations is making the wire hit a ground and causing a short circuit. Follow the power wire of the headlight bulb and look for anything unusual. Replacing the wire is easy and should not cost anymore than a few bucks if you don't have wire laying around.
post #4 of 16 (permalink) Old 01-04-2012, 06:34 PM
You took it to an electrician or a car repair shop?
It only takes a small increase in resistance in that high current circuit to heat up the connector terminals & melt the connector plastic. Check your pigtails for melting. If melted you'll need to replace them. It's a pretty common problem.
Best practice is to apply dielectric silicone grease to all the terminals on the high current side of the headlamp circuit. It prevents corrosion from occurring in the first place.
post #5 of 16 (permalink) Old 01-18-2012, 07:50 PM Thread Starter
So I replaced the sockets (cost about 8 dollars each), and the right lowbeam light works perfect. It doesn't go out anymore, but the left one keeps going out! I replaced the socket and then put a new lowbeam bulb and the bulb turns on at first, but after a while of being on it turns off again, light bulb isn't burned out, but idk wtf to do now! Replaced fuses, 3 pairs of bulbs, and now sockets..I figured sockets would be the problem because they werre melted in the inside..right one works, but left one doesn't..it turns on but after a while it goes out...any other suggestions?
post #6 of 16 (permalink) Old 01-18-2012, 09:56 PM
I'm not sure what you mean, you replaced the female connector but not the male? You may need to replace the male connector also. If the lamps aren't burning out now there must still be an intermittent connection in the left headlamp lowbeam circuit.
post #7 of 16 (permalink) Old 01-18-2012, 10:23 PM Thread Starter
What do you mean the male connector as well?? Sorry I'm kind of new to this....
I took out the light bulb and looked inside where you plug it in, and the plastic was melting and coming in contact with the "teeth"..I took the car to a mechanic that deals with electrical problems in cars...he said to replace the sockets where you plug in the light bulbs..so I replaced both passenger and driver sockets for lowbeam..the right one works perfect now...but left doesn't..it turns on for a bit then the light bulb goes out after a while, but if you look at the bulb it still looks new the inside of it isn't fried or anything..so I'm really confused..what else can I look at???
post #8 of 16 (permalink) Old 01-19-2012, 02:43 AM
I'm talking about the harness connector that you had to disconnect to pull the headlamp housing from the car. It may also have melted. In fact, that's typically the one that does.
post #9 of 16 (permalink) Old 01-19-2012, 11:27 AM Thread Starter
Yeah! That's the part I replaced, I put in new ones..the right one works, but left one doesn't..I don't get it...what else could it be..
post #10 of 16 (permalink) Old 01-19-2012, 02:48 PM
Can you post a picture or point to a web page that shows exactly what was replaced?
post #11 of 16 (permalink) Old 01-19-2012, 03:12 PM Thread Starter
I'm on my phone and can't upload a picture, but google headlight socket pontiac g6, and under images should be the first one on the left..the black one..its next to a grey one
post #12 of 16 (permalink) Old 01-21-2012, 09:10 PM Thread Starter
here you go, finally got on a computer..this is the part i replaced, and it still burns out..
post #13 of 16 (permalink) Old 01-21-2012, 09:11 PM Thread Starter
the whole socket for the left and right side lowbeam headlights
post #14 of 16 (permalink) Old 01-21-2012, 09:55 PM
You usually need to replace the harness-side male connector as well. The corrosion builds up on both sides of the contacting terminals. If the male isn't melted, you might get away with pulling the connector apart & cleaning the terminals til they shine.
I hope you took to heart the advice about using dielectric silicone on the terminals. Makes all the difference preventing corrosion in the first place.
post #15 of 16 (permalink) Old 01-22-2012, 12:17 PM Thread Starter
where are those located at? sorry, im not very familiar with all this...can you show me a picture of where they are, or how they look like?
where are the terminals at? its like a whole new language to me lol sorry
2008 G6 GT Hard Top convertible parts issue…. JoethepainPA73 Problems and Solutions 8 09-08-2016 09:06 AM
pontiac g6 start-up issue jeffao Problems and Solutions 10 12-06-2011 09:22 PM
pontiac g6 v6 2008 sedan manual happy56owner G6 Buyer's Guide/General Information 15 01-18-2011 06:55 AM
BMW M3 Sedan (2008) andykhol23 Auto News and Rumors 1 12-21-2008 11:26 PM
New Owner of 2006 Pontiac G6 GT Sedan..... g6mychaelg6 New Member Introductions 0 04-14-2008 07:30 PM
