2007 G6, 2.4L Engine Noise - Pontiac G6 Forum
post #1 of 14 (permalink) Old 11-28-2007, 12:44 PM Thread Starter
Dusty
Dusty35's Avatar
Exclamation 2007 G6, 2.4L Engine Noise
Hello all, I'm looking for some advice from other G6 Owners on their experiece concerning whats normal and what might be not normal engine noise. Both my son and myself own 2007 G6 Sedans with the 2.4L engine ( yeah, I liked his so much, I went and got one too). On my car, the engine starts making a tapping noise once the engine is warmed up. If you are "old" like me....you would say it sounds like a dirty lifter or maybe wrist pin noise....anyway, I took it to the dealer and they checked it out by listening to it and said that its "rotational" noise, don't worry about. Well, thats all well and good ,but my son's car does not have this noise and both are basically identical ( 2.4,auto trans, etc..). What would you do ??
Dusty35 is offline
post #2 of 14 (permalink) Old 11-28-2007, 03:32 PM
G6 Supporter
tmans06-G6-V6's Avatar
Send a message via MSN to tmans06-G6-V6
Tapping Noise
When I startup my G6 and the V6 engine is warmed it has that same tapping noise. I wonder what it might be. 2006, G6, V6 engine.
The Silver G6 Man[/COLOR]
tmans06-G6-V6 is offline
post #3 of 14 (permalink) Old 11-28-2007, 06:52 PM
Jeepin!
ChevelleSSLS6's Avatar
Send a message via AIM to ChevelleSSLS6
I work in quicklube at a Chevrolet dealer, and lots of ecotecs are the same way. I don't know what it is, but from my understanding the ecotec is a great little engine and will run forever. The internals are good for 300hp, the block is good for up to 600 without additional stiffening if I remember right. So GM did it's homework there.
I wouldn't be too worried about it, perhaps running synthetic oil would reduce the noise (due to reduced friction).
My Cars
-1993 Saturn SC2 manual *sold- 2004*
-2000 Pontiac GrandAm SE v6 *sold- 2006*
-1974 AMC Javelin 360v8, 4sp *underfunded project car*
-1996 Jeep Cherokee Country *DD with more uses than a swiss army knife*
-2007 Kawasaki EX650 *comfortable sportbike, summer dry driver*
ChevelleSSLS6 is offline
post #4 of 14 (permalink) Old 11-28-2007, 06:58 PM
G6 Supporter
whats a good synthetic oil to use.
post #5 of 14 (permalink) Old 11-28-2007, 07:08 PM
Jeepin!
I run valvoline semi-synthetic and a wix filter in my Jeep, ditto on the GrandAm, and that worked well.
As for the 3100/3400 valve noise it didn't help a whole lot, but it might be a different noise on the ecotec.
For the supercharged ecotecs and some Corvettes, GM recommends mobil1 synthetic oil.
Amsoil and Royal Purple probably won't hurt, but are more expensive, so I wouldn't use these unless they're used in competition (which being a 4cyl/auto probably isn't)
My Cars
post #6 of 14 (permalink) Old 11-28-2007, 07:11 PM
G6 Supporter
Arrow Remote Start
How Much Do U Know About Pontiac Remote Start Systems
post #7 of 14 (permalink) Old 11-28-2007, 09:13 PM Thread Starter
Dusty
Dusty35's Avatar
Thanks for the input, I appreciate the help........if you say a lot of them do this, then it must be something that is "normal" to the 2.4L. By the way, I like your reference to the Javelin being an Underfunded project car....thats the story of my life too . Thanks again...
Dusty35 is offline
post #8 of 14 (permalink) Old 11-28-2007, 09:27 PM Thread Starter
Dusty
Dusty35's Avatar
So if GM recommends 5W-30 for the engine, what viscosity Mobil 1 can be used? I've never seen a 5W-30 Mobil 1. What do you recommend? I use the Valvoline Durablend in my other vehicles.
Dusty35 is offline
post #9 of 14 (permalink) Old 12-29-2007, 10:49 AM
Tapping noise
I have the same taping noise in my G6-4 cylinder and had same ticking noise in an earlier Blazer. They first told me that was normal and when I told them to bring a new 4 cylinder into the service dept it did not do it. Come to find out that it is related to the electric fuel pump and the noise is reverburated throught the fuel line. They can fix it if you scream loud enough !I had to get the factory rep involved !
Jim Bunch is offline
post #10 of 14 (permalink) Old 12-30-2007, 12:22 AM
G6 Supporter
I have the same tapping noise on my V6 as well, it must be normal
post #11 of 14 (permalink) Old 01-02-2008, 08:52 PM Thread Starter
Dusty
Dusty35's Avatar
Update: I changed the oil / filter last weekend at 3800 miles...used Castrol Syntec 5W-30, I wanted to see if it would reduce the "noise", it did not. I'm still glad that I went to the full synthetic as it will improve oiling at startup in cold weather. Does anyone know exactly how the "oil Life monitoring" system really works ? I read somewhere that it utilizes some type of sensor, I'm doubtfull that this is correct, otherwise why would the Owners manual advise that if you accidentally reset the oil life, you must change the oil within 3000 miles ?
Dusty35 is offline
post #12 of 14 (permalink) Old 02-22-2009, 09:59 AM
I have had that same noise right off the lot 3 years ago. I have an 2006.
Lilspree is offline
post #13 of 14 (permalink) Old 02-23-2009, 07:19 PM Thread Starter
Dusty
Dusty35's Avatar
Thanks Lilspree, so how many miles do you have on your G6? I've just turned over 12,000 and the "noise" is still there. I keep thinking that its going to get worse. If you've got a lot more miles and have not had a problem, then maybe I should ignore it and enjoy the drive.
Dusty35 is offline
post #14 of 14 (permalink) Old 02-24-2009, 08:55 AM
I have 45000 and the only problem I have had with the car is a popping sound when I turn the wheel. It's not a bad sound but it seems like its coming from the driver side. I have done my research and plenty of people have both problems. (tapping noise in engine, kinda like you have low oil, and this front end noise.)
Lilspree is offline
New G6 Owner here, First thread! Stabbin_G6 New Member Introductions 10 04-12-2011 12:59 PM
2007 G6? jp375 Auto News and Rumors 164 08-26-2006 10:30 PM
Official G6 Convertible Pics xtremegrandam G6 Buyer's Guide/General Information 4 01-05-2005 06:53 PM
