2009 G6 GT Camshaft Position Sensor Replacement - Pontiac G6 Forum
post #1 of 3 (permalink) Old 03-07-2016, 01:09 PM Thread Starter
I've been trying to locate the camshaft position sensor on my 2009 Pontiac G6 GT 3.5L. I ordered the part on Advance Auto Part's website. The part they said that goes with my car is
I've done research online and found a sensor in a difficult spot behind and closer to the bottom of the engine. This sensor looks more like this
I'm confused because my VIN (1G2ZH57N294113876) - specifies that I have a 3.5L V6 engine and the first image should be the correct part. But I've spent hours trying to find the sensor and every sensor I find seems to not fit the electrical connector part and the second image seems to be for a 2.4L engine. Please HELP!
kdub561 is offline
post #2 of 3 (permalink) Old 03-08-2016, 07:49 AM
Here is the location and looks like you bought the right one.
1 - Manifold Absolute Pressure (MAP) Sensor
2 - Ignition Control Module (ICM)
3 - Heated Oxygen Sensor (HO2S) - Bank 1 Sensor 1
4 - Knock Sensor (KS)1
5 - Engine Coolant Temperature (ECT) Sensor
6 - Crankshaft Position (CKP) Sensor
7 - Vehicle Speed Sensor (VSS) (MN5/M15)
8 - Engine Oil Level Sensor
9 - Heated Oxygen Sensor (HO2S) - Bank 1 Sensor 2
10 - Park / Neutral Position (PNP) Switch (MN5)
Waterfowler's 6
post #3 of 3 (permalink) Old 03-08-2016, 10:48 PM Thread Starter
@waterfowler76 - you're awesome! Thank you!!!
kdub561 is offline
Help with Camshaft Position Sensors jpopson43 Problems and Solutions 21 08-31-2015 01:09 PM
P0016 Pontiac G6- Crankshaft Position vs. Intake Camshaft Hourani44 Problems and Solutions 5 09-11-2013 12:49 PM
Part number for Camshaft Position Actuator solenoid primetime12 Problems and Solutions 11 07-29-2013 03:44 PM
08 G6 Camshaft Position Sensor Problems ralphie Problems and Solutions 7 02-07-2013 10:56 AM
07 G6 3.5 camshaft position sensor lbc General Maintenance 3 06-28-2010 04:49 AM
