2006 Impala 3.9L motor into 2006 G6 GTP - Pontiac G6 Forum
post #1 of 2 (permalink) Old 04-16-2016, 08:00 PM Thread Starter
Well, I bought an engine for $600 dollars to install into the G6 that I recently bought.
I got the Impala motor stripped down to the block and heads.
I removed all the sensors, exhaust, intake, oil pan.......every thing.
The impala 3.9 Motor is a direct replacement install for same year Malibu but everything on the G6 motor has to be swapped to the Impala motor for the Impala motor to work in the G6.
In a few days I will be pulling the bad 3.9 motor out of the G6 and remove all the pieces on it. I'm curious to to see the damage inside the oil pan.......the G6 engine threw a rod.
I hope the G6 oil pan is not busted .
1.8TTony is offline
post #2 of 2 (permalink) Old 05-18-2017, 02:12 PM
I would like to know more about the outcome of the motor swap.. Strangely, I have a 2006 G6 GTP that has an Impala motor in it, I believe. I am clueless when it comes to mechanical issues. I assume the motor is an Impala motor from a wrecking yard or something because Impala 06 is written on the motor when the cover is removed. I am currently having many issues with the vehicle and would really appreciate talking more with you about it.
maemae is offline
I just got a 2006 G6 GTP bda22490 Appearance Modifications and Lighting 4 02-05-2010 01:05 PM
2006 G6 Gtp pk2000 Members' Rides 9 04-23-2006 12:14 AM
