oil cooler - Pontiac G6 Forum
post #1 of 15 (permalink) Old 05-06-2016, 05:33 AM Thread Starter
oil cooler
I have a 2006 g6 with the 4cyl engine. I need a oil cooler part #12594525. The part is discontinued and all my routes to find it have come up dead-ends. I've tried vintage parts and all the gm and oem part web sites with no luck. Has anyone had this problem before or do you know a place to get this part other than a junk yard or taking the part off and getting it fixed at a radiator shop(no guarantee to work)?
mbolson127@gmail.com is offline
post #2 of 15 (permalink) Old 05-06-2016, 05:45 AM Thread Starter
oil cooler
Or even a place to get a aftermarket cooler. I'm ok with that. Thanks
post #3 of 15 (permalink) Old 05-06-2016, 12:45 PM
I googled and found plenty.
09 G6 2.4 Sun & sound package-Preferred package
225/50R17S factory
post #4 of 15 (permalink) Old 05-13-2016, 10:05 AM
Did you find a solution I have the same problem...
chuckie is offline
post #5 of 15 (permalink) Old 05-13-2016, 10:06 AM
please share link been looking for 3 weeks.
chuckie is offline
post #6 of 15 (permalink) Old 05-13-2016, 10:09 AM
the after market coolers won't work there are 2 holes left in the engine..
chuckie is offline
post #7 of 15 (permalink) Old 05-13-2016, 02:12 PM
Not sure what's wrong, went by p/n.
Buy GM 12594525 Cooler, genuine OEM part
225/50R17S factory
post #8 of 15 (permalink) Old 05-14-2016, 06:42 AM
when I tried these guys no one actually had the part...
chuckie is offline
post #9 of 15 (permalink) Old 05-14-2016, 12:09 PM
Too bad you can't bypass it. The later 2.4 the cooler was dropped, not needed.
225/50R17S factory
post #10 of 15 (permalink) Old 05-15-2016, 07:37 AM
I know , the problem is the oil still needs to flow through it...
chuckie is offline
post #11 of 15 (permalink) Old 05-15-2016, 12:37 PM
That's what I mean, make a adapter so it flows through. Where is it located, I'll look to see how it was eliminated.
225/50R17S factory
post #12 of 15 (permalink) Old 05-16-2016, 04:25 AM
It is behind the oil filter...I had a thought last night...because it leaks internally I may be able to use the cooler as a bypass, I can reinstall it, and plug the coolant ports with high temp oil resistant epoxy then the leak will be contained within the cooler..the coolant hoses extended and joined...sounds feasible?
chuckie is offline
post #13 of 15 (permalink) Old 05-16-2016, 12:09 PM
Could you find some port fitting caps, would be better. You would need a fitting to join the hoses.
225/50R17S factory
post #14 of 15 (permalink) Old 05-17-2016, 05:20 AM
What are port fitting caps?
chuckie is offline
post #15 of 15 (permalink) Old 05-17-2016, 12:36 PM
Blank caps on to the fitting, instead of the hose.
225/50R17S factory
Can a Transaxle Cooler be added to 2007 G6 GT 3.5L tarutter Maintenance Information 2 03-25-2016 05:20 PM
2.4L engine swap without and without oil cooler BobW Problems and Solutions 1 10-20-2015 06:14 AM
2006 2.4L oil cooler leak TRH Problems and Solutions 4 02-15-2015 07:02 PM
How To: Install A Transmission Cooler CruisinG6 HOW-TO 15 06-30-2013 02:49 PM
Transmission Cooler Installed! CruisinG6 Members' Rides 0 06-24-2012 11:49 AM
