HELP! 2007 G6 Door Locks Going Nuts!!! - Pontiac G6 Forum
post #1 of 7 (permalink) Old 08-16-2016, 07:02 AM Thread Starter
So I just pulled into my job and the door locks went crazy. Locking and unlocking randomly multiple times. I had noticed before leaving that it wouldn't remote start but figured the key fob battery was low. I drove to work (no issues) and as soon as I pulled in it went crazy. Not sure what to do. Never had this happen before (original owner).
I'm loathe to take it to the GM dealership here as they charge $140 to even look at a problem. I apologize if this has been covered elsewhere but I couldn't find it.
Se7en is offline
post #2 of 7 (permalink) Old 08-16-2016, 07:26 AM
sounds like a bad actuator.
Waterfowler's 6
post #3 of 7 (permalink) Old 08-16-2016, 08:20 AM Thread Starter
Would that cause the remote start issue too?
Se7en is offline
post #4 of 7 (permalink) Old 08-16-2016, 05:54 PM
Gregorich's Avatar
Was it all four locks or just one?
If it is the actuator, they're fairly easy to replace. When I did mine, I think the dealer wanted $250 (Canadian) for an actuator, a part store was $130 and the wreckers were $30. I went with the wreckers.
Here's a video of how to do it.
As far as the remote start, I'd switch out the battery and see if it works again. That's the cheapest fix to start with. Did you drop it recently? They can be fairly sensitive.
2008 Pontiac G6 - 2.4-litre four cylinder engine - 165,000-kilometres
Gregorich is offline
post #5 of 7 (permalink) Old 08-17-2016, 01:33 PM
Is it a factory remote start or aftermarket?
Krazy T is offline
post #6 of 7 (permalink) Old 08-18-2016, 08:31 AM
Doesn't sound like an actuator to me. If the actuator wasn't working or was struggling to lock or unlock then yes. This sounds more like a body control module problem. Something causing the actuator to cycle.
carnau is offline
post #7 of 7 (permalink) Old 08-18-2016, 12:37 PM Thread Starter
Okay so update...
Looks like it was the key fob. Pulled the battery from the original one (because apparently I'm dumb enough to not have though of that sooner) and the locking/unlocking stopped. Bought a new fob (and brought it to a locksmith (low low cost of $50) and it works again. Oddly though the "lock" dash light stays on while driving and chimes 3 times when I start the car. Is there some lock cycle I'm missing to correct this? Typically that dash light would only come on when I locked the door from the outside.
Se7en is offline
Door locks gone CRAZY on 2006 g6 gurlcj Problems and Solutions 5 05-22-2016 12:47 PM
No power to rear door locks?? BG1 Problems and Solutions 18 02-11-2015 04:31 PM
Cruise Control and Auto door locks not working Smitty07 Problems and Solutions 6 03-02-2014 03:40 PM
08 G6 GT Power door locks SFletcher Problems and Solutions 18 01-16-2014 12:00 AM
07 Pontiac G6 - automatic door locks not working katherine_1983_02 Problems and Solutions 6 06-21-2010 10:16 PM
