P0016 and P0017 together-Crank sensor? - Pontiac G6 Forum
post #1 of 3 (permalink) Old 09-29-2016, 10:24 AM Thread Starter
JordanBlanton's Avatar
The fiancée's 08 Ecotec just had both variable timing solenoids replaced. After replacement, it still has P0016 and P0017 codes. A google search suggests the 2 in conjunction could be the crank position sensor. Does that sound reasonable? It's a relatively inexpensive part, so I don't mind taking a shot at it. My main concern changing it is in the Crankshaft Variation Relearn. I don't believe I'll have access to a TechII scanner (I have a couple friends that MAY have one), so I know that will have to be done by someone else. After sensor replacement but before the relearn, will I be able to drive the car a couple of miles to a shop to do the relearn?
JordanBlanton is offline
post #2 of 3 (permalink) Old 09-29-2016, 11:51 AM
I Replaced both of those and NO relearn was necessary, unless it just did it itself unknown to me....
One tip: DON"T buy then from Rockauto, VERY BAD experience!
bikerdave47 is offline
post #3 of 3 (permalink) Old 09-29-2016, 01:10 PM Thread Starter
What issues did you have with RockAuto? Was it an issue with the part itself or with the service? I've ordered tons of parts from them and not had any issues
P0016 and P0017 FanofG6 Problems and Solutions 4 08-08-2016 10:30 PM
P0016 Pontiac G6- Crankshaft Position vs. Intake Camshaft Hourani44 Problems and Solutions 5 09-11-2013 12:49 PM
G6 GTP 3.6 Throwing code P0017! Kevinx Problems and Solutions 9 02-20-2013 07:20 PM
crank sensor location 07 3.6L babydollv76 Problems and Solutions 1 03-07-2011 07:10 PM
No Crank on startup wr1426 Steering Lockup Issues & Discussion 0 10-17-2006 10:17 AM
