Heat Tapping - Pontiac G6 Forum
post #1 of 4 (permalink) Old 11-15-2016, 09:18 PM Thread Starter
V.McCall
Talking Heat Tapping
Why do I hear tapping/clicking sound while my heat is running in my 2005 Pontiac G6 GT?
12752 is offline
post #2 of 4 (permalink) Old 11-16-2016, 10:12 AM
I had this same thing happen in a Chevy I used to have. I believe it's the blower motor. I think it's located behind the globe box. It should have a little hole in the bottom, spray a good amount of white lithium grease in there while it's running. Let it run a bit, then do it again. Apparently something gets dry and makes noise, just needs some lubricant
Sent from my iPhone using Tapatalk
Hydrex is offline
post #3 of 4 (permalink) Old 11-17-2016, 07:55 PM Thread Starter
V.McCall
Appreciate this - thanks!
12752 is offline
post #4 of 4 (permalink) Old 11-18-2016, 06:21 AM
Let me know if that works out for you!
Hydrex is offline
No Heat LPCg6 Problems and Solutions 17 12-05-2015 11:18 PM
2006 G6 v6 Lifter Tapping bad kitt316 Problems and Solutions 0 01-04-2015 05:00 PM
Clicking with Heat On 12752 Problems and Solutions 2 02-08-2014 07:17 AM
Heat Problems Harlem1Der Problems and Solutions 11 12-27-2012 12:07 PM
No heat jburr269 Problems and Solutions 9 01-05-2011 05:13 PM
