Popping in strut - Pontiac G6 Forum
post #1 of 5 (permalink) Old 12-30-2016, 11:54 AM Thread Starter
Popping in strut
I replaced my strut after I bent it inward from hitting a rock and bending my rim in 3 different places... but now that i have it installed when I turn it makes a sound like the spring is popping. I know its coming from the spring because when I turn the spring turns and you can see it get held up for a second then move back into place and make the noise. Sometimes the car will pull to the left or right after this happens. Anyone know how to fix it?
Sent from my SM-G930V using Tapatalk
Reynolds1029 is offline
post #2 of 5 (permalink) Old 12-31-2016, 07:36 AM
Old far...er...tinkerer..
When you see the spring turn, is it moving at the top or bottom of the spring?
I suspect the strut mount (at top) is bad - they can get damaged in an accident such as yours.
Doug
plano_doug is online now
post #3 of 5 (permalink) Old 12-31-2016, 09:26 AM Thread Starter
S
post #4 of 5 (permalink) Old 12-31-2016, 09:28 AM Thread Starter
Doug
The bottom is moving and popping I will double check later. I thought the spring was supposed to rotate in the strut when you steer though
post #5 of 5 (permalink) Old 01-01-2017, 08:45 AM
The bottom is moving and popping I will double check later. I thought the spring was supposed to rotate in the strut when you steer though.
Almost the entire strut should move together when the steering wheel is turned. So the spring should remain in the same relative position with respect to the strut.
The only part of the strut that does not turn is strut mount, the upper portion bolted to the shock tower. There is a bearing in it which allows the strut below it to turn while the mount remains stationary.
If the spring is trying to turn relative to the strut, then it appears the bearing in the strut mount is sticking - the strut mount may need to be replaced.
After the car had been run up on a curb, my son's 02 Impala needed a control arm and an inner tie rod (and a wheel). Later, we realized it needed a strut mount as well - it was popping, and STICKING, which is frightful when you're steering the car.
Doug
Popping noise going over bumps? AWick20 Problems and Solutions 0 03-11-2012 09:43 PM
popping sound with steering. coleigh322 Problems and Solutions 1 08-16-2011 05:42 AM
Bolt on Strut Bar Broken----Do I need a new strut? wzbhnn Problems and Solutions 17 04-01-2011 08:51 AM
rattling/popping. etc deannanoel07 Problems and Solutions 0 07-21-2010 11:54 AM
Steering Popping jamestg6gt07 General Maintenance 4 06-04-2009 01:24 AM
