06 g6 3.5 L no spark. - Pontiac G6 Forum
post #1 of 1 (permalink) Old 01-05-2017, 07:48 AM Thread Starter
I have a 06 g6 3.5 v6 with no spark.
Was driver to work and hard a buzzing sound coming from the driver side behind the fire wall. Car stalled costed to a parking lot. Car would not start. Checked plugs and no spark so I thought maybe the coil pack so replaced that still no spark. Next I removed the crank position sensor and the tip was melted / burns off. So I replaced the crank position sensor. Still no spark. So my next thought was maybe the timeing belt broke so I pulled the oil cap and I see valves moving so timing belt is good. Fuel pressure is good.
Replaced items
coil pack
Crank position sensor
Plugs
Wires
Still no spark.
Anyone here have an idea what is wrong. I'm lost at this point.
Amshnock is offline
Spark plugs? Which ones to use? glanzergtx General Maintenance 16 01-16-2014 02:17 PM
Spark plugs Skyhighskye General Maintenance 17 02-14-2013 05:41 PM
Anyone know the best spark plugs for a 06 G6 Preston General Maintenance 8 03-21-2011 09:51 PM
Spark Plugs gmitch23 General Maintenance 19 12-03-2010 06:58 PM
Spark Plugs...help? Altami Powertrain Performance Modifications 12 07-02-2008 12:31 AM
