HELP - Reprogramming New Key Manually - None of the lights, sensors, locks work - Pontiac G6 Forum
post #1 of 1 (permalink) Old 01-09-2017, 10:50 PM Thread Starter
Unhappy HELP - Reprogramming New Key Manually - None of the lights, sensors, locks work
HELP! I have manually programmed a Pontiac 2007 G6 GTP Coupe key previously without having to have it towed and re programmed for an outrageous cost.
First 3 attempts did not work doing the 10:30 on, several seconds off three round rotation.
The lights kept auto turning on so I help help off on auto start and the lights started making flashing movements. Did this twice. Shut off mid sequence and now the key won't turn anything on just makes a weird start noise and the yellow lock light indicator is not just flashing and slowing stopping flashing. WAHHH!
SOS!
HELP!
helpfromdetroit is offline
iKeyless.com Key FOBs do not work! supercjr Product Reviews 8 05-31-2015 09:10 AM
Right side blinkers emergency lights and brake lights wont work maclax Problems and Solutions 0 11-12-2012 02:22 PM
Alarm goes off when I unlock door with key manually carraser891 Problems and Solutions 3 07-03-2011 09:15 PM
2005 G6 Rear Turn Lights / Brake Lights Don't Work G6Ontario Problems and Solutions 11 01-05-2010 04:38 PM
Reverse lights out & speed controlled door locks out ENIEFT Problems and Solutions 0 01-26-2008 12:28 AM
