Tiptronic/Manual Mode Will Not Engage - Pontiac G6 Forum
post #1 of 5 (permalink) Old 02-13-2017, 12:48 AM Thread Starter
Hey all,
My car shifts perfectly fine in Drive. However, when I shift into manual (tiptronic) mode, I don't even get the gear number appearing on my dashboard. Pushing the gear selector also does not change gears. Any ideas? Thanks!
spjohnson1031 is offline
post #2 of 5 (permalink) Old 02-15-2017, 10:50 PM
What have you been playing with? Sounds like there's a config on the car which makes it think there is no tiptronic. Replace any modules recently?
ItsJustGordon is offline
post #3 of 5 (permalink) Old 02-16-2017, 08:19 PM
davez26's Avatar
Recently I changed out a switch on the shifter, as intermittently could not tapshift.
There are two (actually 3), switches in the top of the shifter, push to the side actuates a switch that 'tells' the car it is in tap shift, then the upshift downshift switches front and back.
I'd have to guess that first switch isn't telling the car it's tapshifft time.
I didn't want to replace the whole shifter, just the switch. I purchased a whole shifter assm eBay, then practiced on that to figure how take apart just what I needed and replace it. I had to pull the console, but it wasn't that bad.
Again, this is just my guess on your issue.
Sent from my iPad using Tapatalk
davez26 is offline
post #4 of 5 (permalink) Old Today, 10:38 AM Thread Starter
I have not played with much of anything. Just bought the car a few weeks ago.
post #5 of 5 (permalink) Old Today, 10:39 AM Thread Starter
Any idea where I can purchase the switches? Can they be replaced from the interior or does the trans need to be dropped?
06 GT won't downshift in manual mode! 360ci Problems and Solutions 2 03-31-2013 07:44 AM
Driving in manual mode? HalSwisher Powertrain Performance Modifications 8 05-13-2012 10:33 AM
How To: Effectively Use Manual Shift Mode jpbales Maintenance Information 20 09-15-2010 03:57 PM
Manual shift Mode not shifting Pimpin007 Problems and Solutions 11 08-31-2010 06:59 AM
Manual Shift Mode Issues skidz15 Problems and Solutions 1 05-30-2009 06:30 PM
