G6 wont start - Pontiac G6 Forum
post #1 of 2 (permalink) Old 03-16-2017, 06:24 PM Thread Starter
G6 wont start
Hello yall. Long time lurker, g-series enthusist
I recently got a second g6 for my g-series fleet(standard model). Today it began to crank hard. So naturally i took it to Advance auto parts for a check up. Everything came back position but as soon as i got home, the car refused to start anymore. No sound, no crank but the lights lit up.
Eventually i tried to start it again and it cranked for a second, failed, and a puff of white smoke arose from the engine. Do not know what to do
Few tidbits: the. battery is a month old. A few ago Chevy replaced the key ignition. Power steering and something with the brakes.
Thank you
Jordon Buchanan is offline
post #2 of 2 (permalink) Old 03-16-2017, 07:06 PM
Old far...er...tinkerer..
Thank you
It's reasonable to assume it's not the battery. So it's either a wiring issue or the starter. I would inspect the battery cables for a bad connection - usually corrosion. Trace them from the battery and follow them out to be sure there's not a bad connection downstream such as at the starter. If all the wiring is good, the next thing is to remove the starter and have it tested at a parts store. If the starter tests as good, the battery is the next thing to be tested. I doubt it's bad, but it's not unheard of for a new battery to be bad.
Doug
plano_doug is offline
New to me, g6 wont start kurtt New Member Introductions 3 04-05-2016 09:04 AM
wont start sometimes...please help mick102288 Problems and Solutions 3 02-09-2012 11:28 PM
My G6 wont start Lampoon Problems and Solutions 9 11-20-2011 07:23 AM
G6 wont Start abrumage Problems and Solutions 8 06-28-2010 09:06 AM
HELP My G6 wont start!!! ryan9334 Problems and Solutions 4 11-27-2009 09:43 AM
