Front Engine Cover Gasket? - Pontiac G6 Forum
post #1 of 3 (permalink) Old 04-12-2017, 05:26 PM Thread Starter
I got my car back from the mechanic today and on the inspection report it says I have an oil leak, and said it's the "Front Engine Cover Gasket" but I am not sure exactly where that would be located.
I do not have any oil spots on my driveway, and I don't see any oil residue anywhere on the motor. What should I be looking for?
Also, is this the same as a head gasket? Or is this just the top engine gasket or something instead?
AZJR is offline
post #2 of 3 (permalink) Old 04-13-2017, 07:41 AM
sounds like it would be your timing cover gasket. it'll be in front of your engine..(or pass side) behind serpentine belt.
post #3 of 3 (permalink) Old 04-17-2017, 09:50 AM Thread Starter
Thanks, just confirmed it's the timing cover gasket. I am not getting any dripping to the ground, but I do see some fresh oil in the area in the area. What should this cost to replace? I am getting wildly different quotes from different shops, the dealership wants $660, the local guy down the road wants $370, and the mobile guy wants $110 + parts which seems insanely low.
AZJR is offline
Front crankshaft seal and valve cover gasket J dog Problems and Solutions 2 02-26-2016 01:24 PM
Looking for rubber gasket between engine cover and throttle body pimpninja Items Wanted 0 04-07-2014 02:21 PM
WTB: Rear Monsoon 6x9 , 3.5 Engine Cover , Front End Bra irod87 Items Wanted 2 03-28-2013 11:49 AM
my engine cover blkgtpconvtgirl Appearance Modifications and Lighting 7 05-13-2009 11:41 PM
2.2L '2200' Valve cover gasket oil leak sunrunner_pei GMOC Archived Threads 1 02-13-2007 08:00 PM
