HELP!!! 2010 G6 Idle Problems less then 50,000 miles - Pontiac G6 Forum
post #1 of 1 (permalink) Old 05-16-2017, 01:55 PM Thread Starter
I have a 2010 2.4L G6. Recently I changed the spark plugs in my vehicle (I made sure they were the right brand and gaped properly). After I did this I attempted to start my vehicle and how it is having trouble idling. It turned on and would run a little, sputter a great deal and then cut off. I checked to make sure my clips are good and they were. I also checked my connectors for my coils. I've changed my Mass Air flow sensor given that I was getting a code for it. I also changed my crank sensor (but haven't been able to do a crank relearn because my car won't run long enough to make it to a shop). I am getting a 'crank sensor circuit low' code and an Emissions code but I don't believe it would be causInf the problem. Any ideas on what I could or should do next? Cuz the only thing I could think is I'm having a misfire and maybe my fuel injectors are bad but I didnt have any problems driving before I changed my spark plugs. Please help!
Mikejoel is offline
90,000 miles maintenance pimpninja Problems and Solutions 4 02-12-2014 07:26 AM
Approaching 200,000 miles!!! Joe_H9 General Maintenance 4 10-08-2011 02:25 AM
50,000 miles maintenance gov135 General Maintenance 1 04-24-2010 05:55 PM
Work done on my 2005 G6 with 63,000 miles . wheat67 New Member Introductions 1 01-23-2010 11:14 AM
brake change at 21,000 miles??? hmorneau General Maintenance 6 01-16-2010 08:15 AM
