07 Pontiac G6 - automatic door locks not working - Pontiac G6 Forum
post #1 of 7 (permalink) Old 06-21-2010, 07:57 AM Thread Starter
Unhappy 07 Pontiac G6 - automatic door locks not working
The other day while I was driving down the highway my pup decided to hit my shifter into neutral and now my automatic door locks do not work. It does lock by pressing the lock button on the door and on the remote. I have already checked all of the fuses and they appear to be ok. Any thoughts on how to fix this? I really like the feature. Thank you in advance!
katherine_1983_02 is offline
post #2 of 7 (permalink) Old 06-21-2010, 08:04 AM
do you mean the delay lock? (when you press lock and the doors lock about 15 sec after doors close?)
post #3 of 7 (permalink) Old 06-21-2010, 08:06 AM
GTP 06
maykevin5's Avatar
Send a message via MSN to maykevin5
check the menu settings on the radio to make sure unlock is set to shift to park. If it is, there is a switch in the shifter to scene when it is in park. That might be screwed up. Does the key less entry unlock the doors?
maykevin5 is offline
post #4 of 7 (permalink) Old 06-21-2010, 08:33 AM Thread Starter
waterfowler76:
The lock button works right away.
maykevin5:
I will have to check my menu settings. I didn't even think about that because it had worked before. Do you know exactly what menu it may be under? Yes, the keyless entry does work.
Thanks!
post #5 of 7 (permalink) Old 06-21-2010, 08:38 AM
click here for the ownrs manual and i think its page 216
post #6 of 7 (permalink) Old 06-21-2010, 08:51 AM Thread Starter
Great thanks waterfowler76 & maykevin5. I will have to check that out.
post #7 of 7 (permalink) Old 06-21-2010, 10:16 PM Thread Starter
I had check the menu on my radio and everything was set properly, so I was talking to my dad about it, who is a mechanic, we decided to hook it up to his dyanostic computer to see if it would throw a code. Which it said it was a malfunction in the transmission sensor. We turn the car off and back on and the code cleared itself and everything started working fine. Wish I would have thought of that sooner! Lol. Thanks everyone!
08 G6 GT Power door locks SFletcher Problems and Solutions 18 01-16-2014 12:00 AM
2006 Pontiac G6 GT 2-door build Speed Mafia Powertrain Performance Modifications 21 06-23-2012 06:08 PM
cruise and door auto lock not working keith5 Problems and Solutions 1 03-14-2011 03:30 PM
Reverse lights out & speed controlled door locks out ENIEFT Problems and Solutions 0 01-25-2008 11:28 PM
