2008 Pontiac G6 3.5 Intermittent No Start - Pontiac G6 Forum
post #1 of 4 (permalink) Old 11-02-2010, 08:43 PM Thread Starter
This one has got me stumped. I'm ready to just trade it in and start anew. Here's the issue. Key in ignition. Try and crank but seems to only engage the starter as it spins but it will not start. Replaced Starter. Still having issue. Have had it towed to shop twice and each time it arrives at the shop and they go to start it it starts right up. Can't reproduce. Please help quickly . I can't keep renting a car every time this thing doesn't start.
eric99gt is offline
post #2 of 4 (permalink) Old 11-02-2010, 10:31 PM
there was another thread about same issue but i dont think that the starter was spinning....I'll look around if I find it ill update
Waterfowler's 6
post #3 of 4 (permalink) Old 11-02-2010, 11:12 PM
Professional geek
If the starter turns the engine when you crank it, it is not the starter. It would either be a fuel delivery or an ignition problem. Is the security light on when you crank it? If so, the BCM is preventing you from starting it because it cannot read the transponder in the key. It could also be a fuel pump or PCM problem. Any other lights on? Have you tried cranking it again after 5 or 10 minutes? More details = advice that will be more on target.
~ MattInSoCal
MattInSoCal is offline
post #4 of 4 (permalink) Old 11-03-2010, 07:32 AM Thread Starter
The engine does not crank. Just a spinning sound the first 2 or 3 times you try and crank the engine. Then after that...nothing. It's my wife's car so I'll have to check with her regarding the security light.
eric99gt is offline
2008 G6 Will Not Start irocj12 Problems and Solutions 6 07-27-2010 11:51 AM
2008 Pontiac G6 Air Filter Issues pontiac_G6_owner Problems and Solutions 13 07-08-2010 09:43 PM
2005 Pontiac G6 won't start with warm engine baltimoreG6 Problems and Solutions 6 01-13-2009 06:43 AM
2008 Pontiac G6 - Review Test Drive tzh G6 Buyer's Guide/General Information 0 06-01-2008 04:11 AM
