2006 G6 Gt Spare tire CHECK IT!!! - Pontiac G6 Forum
post #1 of 2 (permalink) Old 11-20-2012, 01:53 PM Thread Starter
I was getting my air pressure checked like I do every month and I also check the spare. Went to check the spares air and noticed the tread was separating from the tire!!! The guy at the tire store said you don't usually see this happen on a car only 6 years old. Had to buy a new spare on the spot, so glad I had checked my air!
AllthumbsMike is offline
post #2 of 2 (permalink) Old 12-26-2012, 09:49 AM
A lot of people don't bother to check the spare. I check mine every month although it can be a pain at times in the winter months, but it's worthwhile. On my old cars with full size spares I would rotate in the spare tire so all five tires would wear down evenly. Compact spares can't be driven at highways speeds so it's utterly useless until you get a flat, and most owners only wait until then to realize it has no air, or as you mentioned, the tread has started to peel off!
My '99 Taurus spare has been used a few times over the years and shockingly enough, it maintains itself at 50psi. I only had to top it up with air once in the last 13 years. My 2 year old motorcycle tires have more cracks then the spare tire does!
'11 Ram SXT 4x4 quad cab - 5.7L V8; 92,200kms
'06 Pontiac G6 GT - 3.5L V6; 136,000kms
'12 Chrysler 200 - 3.6L V6; 79,000kms
360ci is offline
"svc tire monitor" and "check tire pressure" dana6189 General Maintenance 2 03-10-2012 04:22 AM
Spare tire cover anti colaps support gface2k Problems and Solutions 7 11-02-2011 09:33 PM
Spare tire removal performance gains? g6ForTheWin Powertrain Performance Modifications 27 03-19-2011 01:22 PM
Does the 2006 Pontiac G6 give tire pressure? NattyPButter G6 Buyer's Guide/General Information 1 02-08-2010 06:22 PM
2008 G6 Water to the top in spare tire well honey1 Testing, Testing, 1, 2, 3 10 03-03-2009 01:24 PM
