3.5L 07 G6 V6 - Low coolant? - Pontiac G6 Forum
post #1 of 12 (permalink) Old 05-17-2010, 11:55 AM Thread Starter
I've searched and read the threads on Coolant Loss but generally speaking is it normal for the vehicle to lose coolant? I'm half way from the fill line on my G6. I didn't notice it when I looked at the car for purchase and am kinda worried. Its an 07 with only 31k miles on it.
I'm going to top it up after work and watch it closely, any specifics on what I should check besides the hoses and looking for sludgy goo around the intake manifold? I heard about the water pump but any way to tell if thats the cause?
saberz is offline
post #2 of 12 (permalink) Old 05-21-2010, 06:31 AM
Coolant should never be filled to the top of the reservoir, it should be kept between the fill and full marks. Just like engine oil; filling it to the max causes the engine to work harder, and unless you burn through oil, it's not necessary to fill it all the way up.
Just keep an eye on the level for now. I don't have any problems with my '06 GT as far as coolant goes.
'11 Ram SXT 4x4 quad cab - 5.7L V8; 92,200kms
'06 Pontiac G6 GT - 3.5L V6; 136,000kms
'12 Chrysler 200 - 3.6L V6; 79,000kms
360ci is offline
post #3 of 12 (permalink) Old 05-21-2010, 09:03 PM
Hi there, check out my thread of a coolant problem I had:
Low coolant light coming on?
legalcat is offline
post #4 of 12 (permalink) Old 05-24-2010, 08:10 AM Thread Starter
Well, I didn't fill it up all the way, I added coolant to the Cold Line it should be at. A few days later I checked up on it and it was all gone and I heard water sloshing around. I also noticed my hoses under the tank were soaked with coolant. So I filled it up again, and drove home from work(where I checked it). Got home and popped the hood, turned the car off(this is a good test to do, but please be careful). This is to check if your tank/drain hose is the cause.
Car off, pressure build up in the reservoir tank, I slowly unscrew the tank cap(slow so you can hear it depressurize little by little. As its doing this coolant begins to pour from the bottom of tank where the quasi wet dexcool is covering the hoses from previous leaking. So It's coming from the bottom of the tank, not sure if its the tank or the hose but I went onto Amazon and bought a new tank and cap for $38 shipped. I'll tackle this and let you guys know how it goes or any of my other findings.
saberz is offline
post #5 of 12 (permalink) Old 05-24-2010, 10:03 AM
There was a guy from Texas who did the same thing. Replaced the tank and all was well.
I dont know what ruptured it....he dissappeared from the forums though.
One of those guys who only comes around when there is a problem. lol
post #6 of 12 (permalink) Old 05-25-2010, 06:54 AM Thread Starter
I'll be here, I float around only this site, G6performance and Bobistheoilguy so every night I usually hit each site. I'll post up my results though. I did take a quick video of underneath the tank and it looks like there is a sensor that is unplugged, but I couldn't find the wire for it(maybe its not standard on all g6's) and there is a hole/drain hole with no plug either. I'll try to upload it.
http://img218.imageshack.us/img218/4443/0524101635.mp4
I see lots of coolant/wet coolant by the hole though. Not clear enough to look for cracks or to check the hose.
saberz is offline
post #7 of 12 (permalink) Old 05-28-2010, 08:37 AM Thread Starter
Ok, received the replacement tank and cap yesterday. Took about an hour but I did the swap, made sure everything was nice and snug. Filled tank with Dex-cool and drove the car around for about 15-20 minutes, pulled back into the garage and found no loss of coolant. Usually turning off the car and turning it on would result in drips. These are no longer occuring. Left the vehicle in the garage for about 3 - 4 hours and went to leave. As I am pulling out of the garage I hear the water sloshing sound through the dash(heater core) again. Pop the hood and I'm low on coolant. Figure its possibly from air being in the system so I left it alone to fully cool off over night.
This morning I have the same amount of coolant as I did before the swap(barely any) and added top up. There are no wet marks or leaks anywhere I worked so I took care of that. I read that the water pump would cause the tank to spit coolant out like mine was, so I think it may be my next target. I did notice recently(before the change) my car was starting to make puddles, but a pump going bad at 31k? I am reluctant to take it to the dealer because things may or may not be covered under warranty and dealer fee's are killer.
2007 Pontiac G6 3.5L VVT
+Weathertech Ventvisors
+Hankoook Ventus V4 ES
+08 G6 Headunit w/Aux
+Mobil 1 5w30
saberz is offline
post #8 of 12 (permalink) Old 06-02-2010, 12:09 PM Thread Starter
After that last post fill up, it has been stable, so it may have just been air in the system. $38 for a repair = not bad!
+Mobil 1 5w30
saberz is offline
post #9 of 12 (permalink) Old 01-24-2011, 06:13 PM
Ϊ ẠΜ ǺΜح
i had the same problem wen i got mine it turned out to be the water pump
CAMZ5000 is offline
post #10 of 12 (permalink) Old 01-25-2011, 07:11 AM Thread Starter
Yeah sad to say since winter started I noticed the tank dropped an 1/8th or so. Topped it off again but this time no swooshing/sloshing sound from the heatercore.
Im gonna wait till spring to take a good look, might be the rad or the pump. Top it off my wife's Grand AM needs CV's, brakes/rotors and another wiper motor(2nd one is less than 8 months old). Cheap cheap chinese aftermarket motors. Going OEM or pulling a junkyard one lol.
+Mobil 1 5w30
saberz is offline
post #11 of 12 (permalink) Old 01-26-2011, 02:17 PM
Curious to know if you know, or if anyone else knows; is the coolant pump an aluminum unit?
360ci is offline
post #12 of 12 (permalink) Old 01-09-2017, 10:10 AM
@saberz, Thanks for sharing your coolant leak journey. Just curious, when coolant was disappearing, did the heat also stop working?
That is my issue: phantom coolant loss and no heat (until I add more coolant, then it heats for a day, maybe, and RPMs have to be 2k).
Thanks!
2008 G6 GT
Keep ing
Djjay is offline
Low Coolant? SLICK6GTP Problems and Solutions 23 01-17-2012 12:16 PM
Coolant Leak kcsov6 Problems and Solutions 12 01-07-2012 09:47 PM
Low coolant light coming on? legalcat Problems and Solutions 1 05-21-2010 06:27 AM
Leaking coolant, coolant recovery tank cap. Dvin211 Problems and Solutions 5 05-20-2010 10:52 AM
Coolant leak BlueJacket Problems and Solutions 6 11-19-2009 08:25 AM
