3 inch catback Exhaust - Pontiac G6 Forum
post #1 of 6 (permalink) Old 01-29-2017, 07:26 PM Thread Starter
I have a 2007 GT Sport with the 3.9L and 6-speed manual, and as of right now.....its straight-piped. It actually doesnt sound too bad, but some flaws in the factory exhaust make it pop and rattle under a heavy load. I don't know how many of you have gotten a close look at the merge section of the exhaust on these cars, but its complete crap. Instead of a proper collecter, the two-inch pipes from the cats, are crushed together like this --(][)-- to fit into the 2.5 inch exhaust system. My plan is to replace this with a free flowing custom 2"to3" Y section and run a 3 inch system back from there that will use a muffler (havent decided which type) up front, then Y off at the back of the car with two 3.5" tips on each side similar to a G8 GXP look. I also already have a second rear valance panel to modify if I screw up the first one. Lol
Any ideas on which muffler I should run? Ive already done a good bit of research on here, and other sources, about the dos and donts of exhaust work, and since I will be replacing the stock converters with new oem ones, im not worried about scavenging issues. Even if it hurts performance a bit now, I have some other ideas in the works for this aftermarketless bastard. Lol
2007 G6 GT Sport Package with 6-speed Manual
2001 Chevy Blazer Xtreme *For Sale $3700*
Jake88usmc is offline
post #2 of 6 (permalink) Old 02-02-2017, 08:09 AM
Newellzie's Avatar
Your going to have an issue with the bend around the gas tank between the rear wheel and the gas tank there is not a lot of room there but a single 3" pipe should still work I think. A lot of people like the magnaflow, personally I'm looking at a dynamic VT because of the valve system so on low rpms/ normal driving it's almost as quite as stock, but when you open it up it flows almost as well as a straight through muffler. Basically tho, it's personal preference and what sound you want :P best of luck
Sent from my iPhone using Tapatalk
Newellzie is offline
post #3 of 6 (permalink) Old 02-03-2017, 02:29 PM Thread Starter
This is the design that I have in mind. The whole system will be made from pre-fabbed mandrel bends and welded together.
post #4 of 6 (permalink) Old 02-03-2017, 02:31 PM
Newellzie's Avatar
Where is your muffler going?
post #5 of 6 (permalink) Old 02-04-2017, 12:13 PM Thread Starter
The muffler will either go in the straight section before the fuel tank or I'll use two short mufflers after the axle. I'm considering Moroso Spiral Flow or DynoMax Race bullets since they are available in lengths as short as 6 inches. Also open to other suggestions. lol
post #6 of 6 (permalink) Old 02-04-2017, 01:46 PM
Newellzie's Avatar
Dang that's small aha but no sounds good, I'd love to have that set up too I just don't have a shop to do it aha plus I would like quieter then race bullets . Keep us posted!
*Review* OBX Catback Exhaust bjohnsong6 Product Reviews 15 10-23-2014 07:35 PM
OBX catback exhaust? ill show you the link, should i buy it?! SouthernComfort Powertrain Performance Modifications 4 05-23-2011 11:30 AM
Magnaflow Catback exhaust system? g6ForTheWin Powertrain Performance Modifications 10 01-08-2011 01:18 PM
catback exhaust whg6ite G6 Buyer's Guide/General Information 5 11-09-2009 06:31 AM
My Custom Catback Quote jamestg6gt07 Powertrain Performance Modifications 5 09-05-2009 05:05 PM
