2010 G6 HID installation help???? - Pontiac G6 Forum
post #1 of 2 (permalink) Old 04-13-2017, 08:28 AM Thread Starter
MyG6Wendy's Avatar
Im having difficulties installing a HID kit from XenonHids.com. I had them in my previous car so i know they are good quality and how to hook them up, I have the right bulb size and everything. BUT having trouble fitting the bulb in the headlight while still being able to twist the seal cap back on when the bulb is in place. Has any one else got around this issue? how did you set up the light in the housing while still sealing it off from dust/water? is the connection for the light bulb to the capacitors inside or outside of the headlight housing? are you still able to connect the brights after installation b/c brights wires are connceted to low beam wiring in the headlight housing. ANY HELP not sure if it matters but its a 2010, so might have small variations between previous models in wiring?
Thanks!
MyG6Wendy is offline
post #2 of 2 (permalink) Old 04-15-2017, 02:20 PM
suo
I bought this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
works perfect if you don't want to drill a hole in the existing one
suo is offline
HID Installation tmfrosch9 Appearance Modifications and Lighting 5 07-17-2011 06:03 PM
HID Installation help!!! (desperate!) Raptor Appearance Modifications and Lighting 91 02-21-2011 09:36 AM
HIN-NOPI 2010 SUPERSHOW SOLDIER FIELD, CHICAGO ILLINOIS September 25, 2010 mcwheels Off-Topics 0 09-15-2010 10:05 AM
HID Installation asong10 Appearance Modifications and Lighting 3 02-07-2009 11:57 AM
08 GXP HID Installation coolmanvette75 Appearance Modifications and Lighting 4 03-26-2008 02:32 AM
