Aux-in for stock headunits! how-to guide for G6 - Pontiac G6 Forum
post #1 of 116 (permalink) Old 05-22-2009, 10:43 PM Thread Starter
Lead Foot
luckyedboy66's Avatar
G6 owners rejoice! I found a cheap way to add a quality auxiliary input to a stock G6 headunit! I bought and installed a http://www.amazon.com/Scosche-Audio-FM-Modulator-Universal/dp/B0007THIDQ/ref=pd_bxgy_e_img_b and it works great! Basically you plug youre car's antenna into the Modulator, and the modulator into the headunit. Because it is hardwired, it allows for much better sound quality than a wireless transmitter. It isnt quite cd quality, but its pretty good considering the price.
How-To:
Several People expressed interest in the modulator, so i figured a how-to guide for the G6 couldnt hurt. First off, along with the modulator unit, G6 owners will need antenna adapters because GM vehicles use a micro antenna fitting (http://www.amazon.com/Scosche-Mda-Kb-Micro-Antenna-Adapter/dp/B00009UHK2/ref=pd_bxgy_e_img_b). You will need to remove a good portion of the dash to get at the back of the radio, so http://www.g6performance.com/phpBB3/viewtopic.php?f=29&t=5991 is an excellent tutorial (its a life saver).
After the dash is opened up, find a suitable place to install the modulator. I used double sided tape to stick it in with the fuse box (below and right of the radio). After the modulator is mounted, run the antenna hook-ups behind the radio, hook the modulator into the antenna and headunit using the adapters. Tuck the wires down behind the radio - dont worry, theres plenty of space.
You can see in the picture below were I located everything, and how I wired the power.
In the G6, the fusebox is located conveniently close to the radio, so running the wiring was a breeze.
Now connect the black wire to the frame (see above, bottom right), [edit] and tap (or tuck under) the red wire to the A/C fuse so that it will cut power when the ignition is off. The modulator comes with a 2 amp inline fuse so you dont have to worry about burning it up.
Now that the antenna and power is hooked up you need to find a spot for the power switch and 1/8" mini plug. The unit comes with a nice little housing that can be stuck in a good location, but i wanted to hide mine, so i installed the power and mini plug in the top of the cubby just below the A/C controls.
Now youre pretty much done, but before putting the dash back together, test the system to make sure it works! The modulator can be set to broadcast on 87.9 and 88.1 FM (if i remember right), so pick whichever you want to set the radio to. After youre satisfied that everything works, put the dash back together and youre done! Here are some more pics of the modulator and my finished product.
Thanks for reading ! Let me know what you think and dont hesitate to ask questions if I didnt explain things well enough
EDIT: I found that I was getting some interference when I cranked up the A/C. I looked an noticed that I had the wiring routed up against the A/C electric fan housing (behind the head unit), so I rerouted the wiring further away from it and the audio is clear.
The Auto: Graphite G6 Sedan
Engine: 3.5L V6
Mods: Red Caliper Paint, Window Tint (more to come, but on a college kid's budget)
luckyedboy66 is offline
post #2 of 116 (permalink) Old 05-24-2009, 05:21 PM
Just ordered all the parts, should have them this week!
I was just wondering, what is the easiest way to pull off the dash around the deck?
Thanks
almonteb is offline
post #3 of 116 (permalink) Old 05-25-2009, 05:27 AM
FM modulation...?
How much are all the parts?
post #4 of 116 (permalink) Old 05-25-2009, 08:45 AM Thread Starter
Lead Foot
Thanks
here is the how-to guide i used in removing my dash - it was a life saver! http://www.g6performance.com/phpBB3/viewtopic.php?f=29&t=5991
Originally Posted by Lampoon View Post
FM modulation...?
i paid $30 for the modulator and $16 for the antenna adapters, all from amazon.com. links are in the first post^
Engine: 3.5L V6
post #5 of 116 (permalink) Old 05-26-2009, 10:05 AM
GTP 06
maykevin5's Avatar
Send a message via MSN to maykevin5
Hmm, If you were to go through all that trouble, I would just put the hard wired version in.
maykevin5 is offline
post #6 of 116 (permalink) Old 05-26-2009, 01:10 PM Thread Starter
Lead Foot
mmm im not sure what you mean... it is hard wired. if you mean replacing the head unit, there are several reasons why i didnt: cost and loss of the computer display, mainly.
Engine: 3.5L V6
post #7 of 116 (permalink) Old 05-26-2009, 02:02 PM
GTP 06
maykevin5's Avatar
There's a kit that plugs into the 12 pin connector on the back of the radio. When you press the SRCE button under volume. It changes from Radio to CD to AUX if its plugged in.
post #8 of 116 (permalink) Old 05-26-2009, 09:52 PM Thread Starter
Lead Foot
oh, well... dang it. could you plost a link? i have a suspicion that my route is cheaper, but i will have to keep that in mind.
Engine: 3.5L V6
post #9 of 116 (permalink) Old 05-27-2009, 08:34 AM
GTP 06
maykevin5's Avatar
Your route is cheaper, but you don't really rule out 100% static. If you pause the music some how and crank it up, you'll hear a hissing sound.
here ya go.. http://www.discountcarstereo.com/detail.aspx?ID=446
post #10 of 116 (permalink) Old 06-08-2009, 05:30 PM
Does this method charge while playing? I have an older iPod and the battery is crap. But if I can find something that will connect via the dock connector and charge it while playing, that's a win.
avallach is offline
post #11 of 116 (permalink) Old 06-08-2009, 07:54 PM
Adam R's Avatar
when you go to order it it says it isnt meant for the g6
Adam R is offline
post #12 of 116 (permalink) Old 06-08-2009, 10:50 PM
RedRocket's Avatar
This looks pretty cool and seems like a cheaper way to get an aux input rather than buying a new head unit. Has anybody ever gone this route with the G6 or installed it before?
2007 G6 GT
Debadged, K&N Drop In Air Filter, Pioneer DEH-6200bt w/ Metra Kit, L.E.D. Tailights, L.E.D. 3rd Brake Light, 7500k High beam, Low Beam, and Fog Lights, L.E.D Lights Behind the Grille, L.E.D. Reverse Lamps, Ya, Basically L.E.D.s all over, And more to come....
RedRocket is offline
post #13 of 116 (permalink) Old 06-09-2009, 12:03 AM
GTP 06
maykevin5's Avatar
Think that depends on if you have monsoon or not. they probably don't include the G6 because if its not the monsoon it won't work or something. People getting mixed up..
post #14 of 116 (permalink) Old 06-09-2009, 05:08 PM
RedRocket's Avatar
alright....well i got the monsson, maybe ill order it and make a weekend project out of it....now where to mount that huge box and inputs...?
2007 G6 GT
post #15 of 116 (permalink) Old 06-09-2009, 08:09 PM
RedRocket's Avatar
Talked to the customer service at discount parts direct and here is the link for what would work for a 07 GT with monsoon and no xm
http://www.discountcarstereo.com/detail.aspx?ID=1246
From what i understand if your car totally doesnt have sat radio (what it works through, i think ) then you have to go to the dealer and have them activate it....other wise looks like it should work fine, has a one year warranty and can be returned if it doesnt work. If you search "PXAMG operation in 2009 pontiac G6" on youtube they have a demo
2007 G6 GT
