Struts - how to replace - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > General Maintenance
Thread Tools Display Modes
Old 05-19-2011, 11:58 AM   #1
UT2007G6
Gallery: 0
UT2007G6 is on a distinguished road
Need to replace my struts in my '07 with just over 60k. I have all the parts and tools. Is this an easy job? Any step by step instructions?
__________________
'07 G6 V6
UT2007G6 is offline   Reply With Quote
Old 05-20-2011, 01:31 PM   #2
gface2k
Gallery: 0
gface2k is on a distinguished road
This was my first major mod.
1. Brake lugs
2. Jack car
3. Take tire off
4. Remove stabilizer from strut
5. Remove strut to steering knuckle nut (the 2 big bolts on the strut, on of them is grooved so it does not spin) Remember which one is top and which is bottom.
6. Remove brake line bracket
7. Support Rotor/Lower Control arm so it doesn't just hang
8. Remove strut tower bolts
9. Remove strut
10. Insert an allen wrench an brake the nut that holds the spring
11. Compress spring and remove the nut on the strut
12. Reverse process
13. Get Alignment!!!
Strut shaft nut - 52ft lb
Strut tower - 18lb ft
Stabilizer link - 48lb ft
Strut to steering knuckle - 89lb ft
With 2 people it can be done with in an hour, good luck.
gface2k is offline   Reply With Quote
Old 03-12-2012, 10:12 AM   #3
Slickgtu
Gallery: 0
Slickgtu is on a distinguished road
I am trying to save major $$ by doing this myself and this will definitely come in handy.
Can anyone tell me what tools I will need to complete the job? A friend will loan me spring compressor but I would hate to keep running to the store for the tools I should have had handy in the first place..
thanks a ton
Slickgtu is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
recommendations on new shocks/struts lifelongslacker Handle It! - Suspension, Wheel and Tire Modifications 1 05-22-2011 08:54 AM
2006 Pontiac G6 Struts bstower2007 Problems and Solutions 1 02-15-2011 06:17 PM
How to tell if the struts need replaced? bstower2007 General Maintenance 1 02-14-2011 08:41 AM
Do You Need To Change Struts If You Put Lowering Springs On A G6 MGD1117 Handle It! - Suspension, Wheel and Tire Modifications 5 04-28-2010 12:11 PM
© AutoGuide
