How To: Change fog light bulbs quick and easy - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > HOW-TO
Thread Tools Display Modes
Old 07-06-2011, 01:58 PM   #1
gotzaG6
gotzaG6's Avatar
Gallery: 0
gotzaG6 is on a distinguished road
I know I haven't been on this board very long, but I've worked on cars for at least 15 years here and some of the stuff I see on here scares me a bit. I was searching on how to change the H11 fog light bulbs on the base/GT models and all I found was that I needed to pull the whole headlight out to access the fogs??? WAAY too much work! All that is needed is this:
-Trim panel removal tool
-The bulbs
-10~20 minutes time
1.) lay on your back at the front of the car, by the fog light. You will see a black plastic panel held on by three black plastic retainers (one of which is in a recessed area of the panel at an angle) under the car.
2.) remove the three black plastic retainers with your removal tool (or pair of needle nose pliers, but you might tear the retainer a bit) and the panel will now easily pull down.
3.) remove the light, still plugged in, by twisting up and pulling out. Once the light is out, there is plenty wire to separate the harness from the bulb from below the car.
4.) insert new bulb into the housing without hooking the wire up. The plug will be parallel to the ground and will twist down to lock in place. Now you can easily snap the harness into the bulb.
5.) hold the panel up and re-insert the 3 black plastic retainers until they fit flush to the panel.
That's it. No need to move headlights and wiggle air boxes out of the way. Now mind you, this is for a direct replacement, if you are installing HIDs, you'll need to find a place to mount the ballast (so in that case, maybe removing the headlight might help).
Hope this helps!
__________________
Left a 421RWHP 2004 GTO, but honestly loving the G6 GT coupe!
Past Pontiacs
87' white Firebird(sold)
01' green Grand Am SE2(traded for the 03')
03' orange Grand Am SC/T(totaled)
04' blue GTO(traded for the G6)
Current Pontiacs
00' tan Montana(I swear, its the wife's)
06' black G6 GT Coupe
gotzaG6 is offline   Reply With Quote
Old 07-06-2011, 08:04 PM   #2
reverttheclown
reverttheclown's Avatar
Gallery: 0
reverttheclown is on a distinguished road
6k's are on the way for my fogs to match my headlights and never realized this route...thanks
__________________
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline   Reply With Quote
Old 07-07-2011, 10:38 AM   #3
Lampoon
Gallery: 40
Lampoon is just really niceLampoon is just really niceLampoon is just really niceLampoon is just really nice
Nice write up. I would just recommend u Snap some pix for a "How To".
For wire running and ballast placement you will need to pull the headlight.
Its just two screws but a few of the push pins in that front top fascia
need to come out....
__________________
Lampoon is offline   Reply With Quote
Old 07-07-2011, 10:59 AM   #4
reverttheclown
Gallery: 0
yep already have HID's in fogs so just need to swap out bulbs...this'll be perfect
__________________
Crimson Red
Old 07-07-2011, 12:13 PM   #5
gotzaG6
gotzaG6's Avatar
Gallery: 0
I will get those soon.
__________________
Past Pontiacs
Current Pontiacs
You may not post new threads
You may not post replies
Forum Jump
quick easy mods for 3.5? 3.5g6 Powertrain Performance Modifications 5 08-08-2010 06:07 AM
LED tail light bulbs rychay Appearance Modifications and Lighting 2 03-07-2010 11:15 AM
Replacing Fog Light Bulbs. Gambit General Maintenance 1 05-15-2009 11:48 PM
Fog light bulbs Pippen33KU G6 GXP Discussion 3 10-26-2008 01:27 PM
How hard is it to change headlight bulbs & fog lights? ginuwine Problems and Solutions 3 01-16-2006 01:21 PM
© AutoGuide
