Hit an...animal. Coolant leak. Tank? - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 08-06-2011, 11:59 PM   #1
Waggs
Waggs's Avatar
Gallery: 0
Waggs is on a distinguished road
I hit some animal this evening. It was quite dark, dark colored animal. I didn't even see it coming. No bigger than the bottom of the headlight. All it really damaged was the front valance along with SOME TANK, underneath the driver side headlight. It leaked coolant. All of it. So I know it couldn't be the reserve. (Could it?)
It's some sort of tank. Nothing too special. It leaks only coolant but it leaks every drop of coolant that the car had in it. Just at an idle the car would begin to overheat.
Could use some help on figuring out what this "tank" does, how much a replacement part would be, maybe some "How-To" instructions on how to replace it. And if you would be so kind as to possibly shoot me a link where I could get one online or a part number, if one can't be obtained here at some dealership.
Pics will follow hopefully within the next few days to help me explain this part a little more.
Waggs is offline   Reply With Quote
Old 08-07-2011, 08:45 AM   #2
reverttheclown
reverttheclown's Avatar
Gallery: 0
reverttheclown is on a distinguished road
what color is the fluid...i know the windshield washer tank is right behind the headlight. engine coolant im not sure on the exact location...might depend on engine size? what do you have
__________________
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline   Reply With Quote
Old 08-07-2011, 09:48 AM   #3
Waggs
Waggs's Avatar
Gallery: 0
It's the 3.5L. Positive it is the coolant. The red hue from it pretty much tells me it's coolant. Still Dex-Cool from the dealership. That and just idling for less than 5 minutes and I can watch the needle just rise and rise and rise until it warns me that the engine is over heating.
Old 08-07-2011, 12:10 PM   #4
g6driver
Gallery: 0
g6driver is on a distinguished road
I know the drain for your coolant is there that's the only thing I can think of.
__________________
2006 Pontiac G6 Sedan 3.5 V6
Mods: Drop in K&N Air Filter, Partially debadged, Vinyl overlay on door trim and darts.
To come: Ehaust, Tint and much more.
g6driver is offline   Reply With Quote
Old 08-07-2011, 01:16 PM   #5
greenman
Gallery: 0
Hope this doesn't come across as mothering, but I would advise you to stop running that engine entirely. It doesn't take long to ruin the water pump bearing without coolant running through it. Not to mention cracking the engine head or block.
Old 08-07-2011, 09:49 PM   #6
Waggs
Waggs's Avatar
Gallery: 0
It does. But in a good way. As of now the car is not and will not run until the problem is fixed. By the way I did get it on a lift today. It cracked the plastic part of the radiator on the driver side. Now I would like to know if that is possible to be fixed without replacing the whole radiator and how much that might run.
Old 08-08-2011, 02:08 AM   #7
Jarebear
iz Jared
Jarebear's Avatar
Gallery: 0
Jarebear is on a distinguished road
Send a message via AIM to Jarebear
Check the junkyards for the radiator... It might be your best bet money-wise.
Jarebear is offline   Reply With Quote
Old 08-08-2011, 01:42 PM   #8
greenman
Gallery: 0
A picture would be worth a thousand words.
Old 08-08-2011, 09:44 PM   #9
Waggs
Waggs's Avatar
Gallery: 0
Ill show you what cracked exactly with a couple pictures after I replace it. That is happening this weekend. Its super cheap to get my car on a lift and a radiator is not that expensive. Thanks all for the help though! Lesson learned : don't hit animals.
You may not post new threads
You may not post replies
Forum Jump
Fuel Leak at tank/pump golf_n_motorcycles Problems and Solutions 13 07-20-2013 04:27 AM
coolant leak from recovery tank ohyeahjay Problems and Solutions 10 06-21-2010 03:15 PM
Leaking coolant, coolant recovery tank cap. Dvin211 Problems and Solutions 5 05-20-2010 10:52 AM
New overflow tank for the ol' coolant.... BigGtp GMOC Archived Threads 4 01-17-2007 11:40 PM
Gas Tank Leak!!! lrish Problems and Solutions 2 11-13-2005 07:09 PM
© AutoGuide
