pontiac g6 start-up issue - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 11-17-2011, 09:24 PM   #1
jeffao
Gallery: 0
jeffao is on a distinguished road
Hi. I have a 2005 pontiac g6 gt sedan with almost 60k miles and every now and then, most often when i dont expect it i have a problem starting the car. Ill get in and start it up and the engine will kick like its trying to start and then it will eventually give up and peter-out. Light application of the gas pedal will quickly resolve the issue and it will idle normally. This only happens every now and then, but the majority of the time it starts normally. Anyone know whats going on? Love the car, but it a shame this is happening so early in its life.
jeffao is offline   Reply With Quote
Old 11-17-2011, 10:15 PM   #2
greenman
Gallery: 0
Hard to start when cold, hot or both?
I'd start by cleaning the throttle body & MAF sensor if that hasn't been done.
Could be a fuel delivery issue. I'd want to check the pressure at startup.
Does it turn over normally while cranking or is it a slow crank?
No codes?
No other engine problems? Does it otherwise run ok?
Which engine?
Old 11-18-2011, 09:30 AM   #3
Abyssul
Gallery: 0
Abyssul is on a distinguished road
Definitely clean the throttle body. You can do it in 30 minutes at home so don't take it to a shop.
__________________
Abyssul is offline   Reply With Quote
Old 11-18-2011, 01:33 PM   #4
greenman
Gallery: 0
Cleaning the throttle body (won't be exactly the same but you'll get the idea):
http://www.autorepairfacts.com/repai...vent-problems/
Old 11-18-2011, 06:19 PM   #5
jeffao
Gallery: 0
thanks for the replies! Greenman - itll do it when its hot or cold out. its the 3.5L v6. Its not really a slow crank, like a weak battery, you can feel the engine trying to start (after turning the key to "start" and releasing it) and you can see it on the odometer. The engine spudders and will eventually give up unless I apply some gas. Ill try to start the car again, after its stopped by itself (or turned the key back to off), and it may repeat the same thing or sometimes itll start back up smoothly. The majority of the time it will start like a brand new car. No engine lights come on at all when it happens. Wish i could catch this on video and show it to you guys.
Old 11-18-2011, 06:51 PM   #6
greenman
Gallery: 0
Start with the TB & MAF sensor cleaning.
The Chiltons for G6 has a how-to for removing the MAF sensor. Before removal, get yourself some CRC MAF sensor cleaner at any auto parts joint. Spray the platinum wire/s down thoroughly & let air dry. Then reinstall. Don't touch the fragile wires with anything! Total time is 15 minutes max.
Old 11-18-2011, 07:32 PM   #7
jeffao
Gallery: 0
Thanks, Ill definitely try that when im off from work, but the weather outside here in Maine is starting to get harsh!
Old 11-26-2011, 12:31 PM   #8
CruisinG6
Gallery: 17
CruisinG6 will become famous soon enough
Check the air filter too. If pressing the throttle is helping it start then it could be getting choked up a little.
Like everyone else says. cleaning the MAF and the TB is a good idea. You can get cleaners for both.
Wouldn't hurt to check your plugs, Just pull em and read em, chances are they're fine. But at 60K it might be worth the extra effort.
__________________
~My '09 2.4 G6~
CruisinG6 is offline   Reply With Quote
Old 11-29-2011, 01:00 PM   #9
getonerd
Gallery: 0
getonerd is on a distinguished road
Sweet my does it ones in awhile
Sent from my iPad using Autoguide
__________________
05 G6
ipad mini install
Gametag psn=getonerd 360=geronerd
getonerd is offline   Reply With Quote
Old 12-06-2011, 05:56 PM   #10
jeffao
Gallery: 0
Greenman, is the "chiltons" a repair guide like the "haynes" books? which of the two would you recommend?
Old 12-06-2011, 08:22 PM   #11
greenman
Gallery: 0
They are one & the same company now.
Amazon Amazon
You may not post new threads
You may not post replies
Forum Jump
2006 G6 GT GM remote start issue RyanN Problems and Solutions 3 11-01-2012 12:12 AM
My Pontiac shakes when I start breaking..help Henetra Problems and Solutions 8 02-09-2011 08:14 AM
Remote Start issue LSX_Sean Problems and Solutions 7 01-28-2011 10:19 PM
2008 Pontiac G6 3.5 Intermittent No Start eric99gt Problems and Solutions 3 11-03-2010 06:32 AM
Serious Start-up Issue Gophat Problems and Solutions 9 07-14-2008 08:07 AM
© AutoGuide
