Running hot, for no reason, why? - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 02-19-2012, 12:51 AM   #1
2001goldGTP
Gallery: 0
2001goldGTP is on a distinguished road
So up until last weekend i have never heard the fans in the g6 run. Then while we were coming back from reno, to the sf bay area, the car started to run hot. I stopped at a gas station about 15 miles from tne hotel to get gas and i haer the fans running on high, i mean it sounded intense. The car was over 240F. It statyed pretty high all the way back and it was only in the 40s outside. We stopped at anoher gas station a bit higher up and i cracked open the over flow and let the coolant boil just a tad in the over flow. I didnt let any spill out and i didnt burn myself lol. just as a note, the car made it to reno with out gOing over 225F.
After that it stayed around 225. However it is still running just over 225 and when we park somewhere, either a short drive or a long one, the fans are running hard long after the car is off.nthe coolant level is normal.
The car is a 3.5 with 65k on the clock. Do i need a thermostat? Coolant flush? Or some other random thing?
2001goldGTP is offline   Reply With Quote
Old 02-19-2012, 07:43 AM   #2
G-Sixer
G-Sixer's Avatar
Gallery: 0
G-Sixer is on a distinguished road
Someone else may have a better educated guess than I would but did you check for codes at all? The CEL does not have to be on for there to be stored codes. You can do this at your local Autozone or Advance Auto or you can buy your own scanner which have come down in price considerably.
G-Sixer is offline   Reply With Quote
Old 02-19-2012, 10:51 AM   #3
platinum ws6
Gallery: 0
platinum ws6 is on a distinguished road
If it randomly started doing this I would make sure you did not run over a bag or something that is restricting the air flow to the radiator (sometimes they can make their way in places you would never think of). Next I would check the thermostat because you know your fans are working. If the thermostat is working properly then the only thing left would be your water pump. I don't know much about the G6 water pumps when they are worn out will leak a little out a small hole on the bottom of where the gear is internally. Hope this helps.
__________________
2000 Trans Am WS6: Sebring Silver Metallic LS6, TEA 5.3 stg. 2 heads, VRx5 cam, Monster stg 3 clutch, 3.73 gears, yada yada.....too much more to list.
Daily Driver- 2003 Silverado Z71, 3 inch body lift, 35s, Hypertech
Wife's: 2010 G6 Silver Metallic 3.5 V6 with ebony int.
platinum ws6 is offline   Reply With Quote
Old 02-19-2012, 01:07 PM   #4
greenman
Gallery: 0
Since you aren't seeing any coolant loss or hearing air trapped in the system I would replace the stat. A dragging brake can also cause engine overheating.
Old 02-20-2012, 08:53 PM   #5
2001goldGTP
Gallery: 0
The car doesnt feel like its draging a brake at all but i will look into that. I would expect a couple hundred mile drive would over heat a dragging brake, and i did not see any debris under the car or against the radiator. So im guessing t stat time. Thanks guys.
Old 02-21-2012, 01:00 AM   #6
greenman
Gallery: 0
If you PM me with an email address, I'll send the stat how-to from the GMSI if you need it.
You may not post new threads
You may not post replies
Forum Jump
locked up brakes for no reason railmut Problems and Solutions 2 11-06-2011 02:29 PM
daytime running lights ryangski Problems and Solutions 12 10-12-2011 05:56 PM
3.5 Running Lean With CRABS And GT-R coastiejoe Problems and Solutions 4 09-18-2011 10:59 PM
What A/V setups are you running? RedRocket Car Audio, Video and Security 4 04-29-2011 06:35 AM
Running new speaker wire Dragon12579 Car Audio, Video and Security 9 01-02-2010 04:44 PM
© AutoGuide
