Panoramic sunroof not working HELP! - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 03-09-2012, 08:46 AM   #1
chicagojoe12
Gallery: 0
chicagojoe12 is on a distinguished road
So I have a 2006 G6 Gt 3.5L and the sunroof has stopped working (and the heated seats as well) I push the buttons and nothing happens. I noticed when I had a radio installed a few months back I also have 2 L7 woofers and a 1200w Brutus amp. Not sure if this had anything to do with it but can someone tell me the steps on how to check what the problem is? I went to my dealer and they wanted to charge me $90 just to look at it! Thanks
chicagojoe12 is offline   Reply With Quote
Old 03-09-2012, 10:07 AM   #2
Firedown
Firedown's Avatar
Gallery: 0
Firedown is on a distinguished road
Check the fuses for them. Your owners manual will layout what fuse is where.
__________________
Mods: GT-R exhaust, CRABs O3 w/FPU, 35% tint, 5000K HID lows/fogs, upper/lower recessed grilles, Racingline strut bar, concept darts, white LEDs everywhere
Firedown is offline   Reply With Quote
Old 03-09-2012, 11:16 AM   #3
reverttheclown
reverttheclown's Avatar
Gallery: 0
reverttheclown is on a distinguished road
^ x2 can almost guarantee thats the problem
__________________
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline   Reply With Quote
Old 03-10-2012, 03:40 AM   #4
CruisinG6
Gallery: 17
CruisinG6 will become famous soon enough
Sounds like a fuse problem... I'm pretty sure the circuit for the heated seats and the circuit for the sunroof share the same fuse... Should be red 10 amp. Fuse box is located on the passenger side foot well on the side of the center console area...
__________________
~My '09 2.4 G6~
CruisinG6 is offline   Reply With Quote
Old 03-10-2012, 03:00 PM   #5
chicagojoe12
Gallery: 0
Just replaced the fuses didn't work which worries me more. The fuses are on the left side of the trunk I replaced 9, 10, and 14
Old 03-10-2012, 04:08 PM   #6
greenman
Gallery: 0
The fuse to check is the sunroof/heated seats fuse in the BCM fuse box as CruisinG6 said. If that's open, this may apply:
Service Information 2006 Pontiac G6 | G6 (VIN Z) Service Manual | Document ID: 2323916
#PIC4165C: Power Windows Inop / Heated Seat / Roof Fuse Open - (Aug 7, 2009)
Subject: Power Windows Inop/Heated Seat/Roof Fuse Open
Models: 2008-2009 Chevrolet Malibu (new body style)
2005-2009 Pontiac G6
2007-2009 Saturn Aura
This PI was superseded to add 08 Malibu and update text to include driver and passenger side. Please discard PIC4165B.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A customer might comment that the Power Sunroof, Windows, and/or the Heated seats are inoperative. There have been reports from dealers that the 10 amp roof/heat seat fuse was open in the BCM.
Recommendation/Instructions:
Cause:
Dealers are finding that circuit #243 (YEL) wire, going to LH and or RH Heated Seat switch was found to be shorted to ground. The locations are at the seat track harness pass-though, and or getting pinched by the recliner mechanism for easy access seat operation.
Correction:
Remove the driver and passenger seat outer bezels and inspect for damaged wiring to the heated seat switch. If damaged wiring is found, make the necessary repairs and re-route the harness as needed.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
2012 General Motors Corporation. All rights reserved.
Old 03-10-2012, 09:38 PM   #7
CruisinG6
Gallery: 17
Something tells me this is your problem...
__________________
~My '09 2.4 G6~
Old 03-11-2012, 10:12 AM   #8
chicagojoe12
Gallery: 0
THANK YOU It finally works! Turns out there was NO fuse in there but I put a 10 in it. But now new problem is one of the panels of the sunroof is missing the 2 pins that hold it together =\
Old 03-11-2012, 01:36 PM   #9
greenman
Gallery: 0
The panos are a bit problematic. No idea how you're going to find parts for it.
You may not post new threads
You may not post replies
Forum Jump
panoramic sunroof... Is it really that bad? unicknn Appearance Modifications and Lighting 20 07-20-2011 07:48 PM
Panoramic sunroof won't open CRAIGZ24 Problems and Solutions 3 10-27-2010 01:26 PM
Panoramic Sunroof help... rkalbiar Problems and Solutions 1 02-28-2010 03:15 PM
Panoramic Sunroof racingbaby911 Problems and Solutions 5 06-17-2009 03:04 PM
G6 with panoramic sunroof Eatsleepdrivesc G6 Buyer's Guide/General Information 5 10-20-2008 06:38 PM
© AutoGuide
