Front Door Speaker Replacement - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > Car Audio, Video and Security
Thread Tools Display Modes
Old 08-05-2012, 02:06 PM   #1
iamrambootious
Gallery: 0
iamrambootious is on a distinguished road
i am trying to replace my front speakers in my 06 gtp. obviously i have to get under the door panel. does anyone have any tips on safely doing that? im going to gues theres a s**t ton of wiring and not to mention the window track. i just dont want to mess it up so i cant get it back on or anything.
thanks
iamrambootious is offline   Reply With Quote
Old 08-05-2012, 05:35 PM   #2
P Magic
P Magic's Avatar
Gallery: 6
P Magic is on a distinguished road
Quite simple. For the drivers door you have tinted remove the rubber pad incidental full cup. Unscrew the 2 screws and remove the switch bezel. Then inside the handle cup you'll see an access cover, remove it and then the screws behind it. Gently pull the panel away from the door along the edges and then lift off from door. You may have to release the cable linkage from the inside door handle. Do the same for the passenger door except you need to Oryx off the pull handle trim first.
__________________
P Magic is offline   Reply With Quote
Old 08-06-2012, 07:00 PM   #3
iamrambootious
Gallery: 0
I did not see these 2 other screws. I found the star screw in the handle indent. But I can not find any other screws. There's a fastener that you press a little button to pop it out but that's obviously not holding the panel on
Old 08-07-2012, 09:22 AM   #4
P Magic
P Magic's Avatar
Gallery: 6
They are under here...
And under here...
__________________
Old 08-07-2012, 04:37 PM   #5
Dmanj
SUPER MEMBER
Dmanj's Avatar
Gallery: 11
Dmanj is on a distinguished road
I made a thread in the How-To about removing the door panel. Check it out. It's quite simple
I'll even link it for you. Clicky
Dmanj is offline   Reply With Quote
Old 08-19-2012, 09:23 AM   #6
iamrambootious
Gallery: 0
You guys are the best. Thank you so much
You may not post new threads
You may not post replies
Forum Jump
What type of speaker should I use to replace a blown front speaker? TheQuizzle Car Audio, Video and Security 10 02-06-2012 10:18 AM
Replacement Speaker Help jpdepucci Car Audio, Video and Security 2 11-05-2011 09:08 AM
Front door speaker LilMc10 Car Audio, Video and Security 5 11-20-2010 12:05 AM
door speaker replacement getonerd Car Audio, Video and Security 3 10-17-2010 06:16 PM
Speaker Replacement!!! s1cgtp Problems and Solutions 5 12-10-2008 11:22 AM
© AutoGuide
