G6 transmission service intervals - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > General Maintenance > Maintenance Information
Thread Tools Display Modes
Old 08-12-2012, 10:55 AM   #1
plano_doug
Old far...er...tinkerer..
Gallery: 0
plano_doug is on a distinguished road
Hi, My wife has a 2007 G6 which just hit 100,000 miles. I was checking into changing the fluid and filter in the transmission and was surprised at what's in the manual. If I understand this correctly, if the car is being used in rough service, the fluid and filter are to be changed every 50,000 miles, but if it's not used in rough service, they never need to be changed. I would still expect them to recommend changing them at 100k. Can you add anything to this? Is there an addendum to the manual which has a different recommendation?
I've had two 4T65E's rebuilt in other cars, and don't want to deal with adding the G6's 4T45 to that list.
Doug
plano_doug is offline   Reply With Quote
Old 08-12-2012, 06:31 PM   #2
CruisinG6
Gallery: 17
CruisinG6 will become famous soon enough
I was reading around because I'm planning on doing a pan drop and filter replace (Just hit 50,000) and from what I've read it's supposed to be a maintenance free transmission. But I think what that really means is they want you to go to the dealer to get it serviced, hence the missing dipstick.
A filter replacement is a good idea every 50k IMO and maybe a complete flush every 100K
I'd say to get your fluid flushed, regardless of how the car has been driven. It'll replace more of the fluid. But I'm not sure if they still go in and replace the filter. I would think so but I never had a car long enough to decide to do a complete flush.
Doing a pan drop and filter replacement will replace 6.9qt of fluid.
Doing a flush I believe will replace 9.5qt
And when the transmission is first built with not a single drop inside. It takes 12.9qt to fill it up.
After whatever job is done you then need to have the car on a level surface. They say to raise it up, but I think you can do it while it's on the ground because of where the check plug is located. But as you fill you have to crack open a little check plug and just go slowly until fluid drips from there, that's when it's full and you're done.
I got a majority of my info from the Malibu forums. Seeing as the Malibu is the same car, I figure it's well worth following.
http://www.chevymalibuforum.com/foru...ead.php?t=7641
And according to my Chiltons for G6 (Worth the $15) The 2005 G6 used Dex3 fluid and 2006 and up use Dex6.
As an added touch I even added a trans cooler to help extend the life, Heat is one of the most common causes of transmission failure. Not to mention is also made my transmission perform pretty nicely.
__________________
~My '09 2.4 G6~
CruisinG6 is offline   Reply With Quote
Old 08-13-2012, 07:43 AM   #3
plano_doug
Gallery: 0
Originally Posted by CruisinG6 View Post
(Snip great post.)
And according to my Chiltons for G6 (Worth the $15)...
Thanks, CruisinG6. Great post! I've duly bookmarked the Malibu write-up - it's an excellent reference.
I think I'll swap the fluid and filter. Not sure I can do much more than the 6.9 quart swap in my driveway. But, at 100k miles, it seems like it should be changed.
As for the Chilton's, I already have the Haynes, but, in this case, I failed to RTFM
Doug
Old 08-14-2012, 02:01 AM   #4
CruisinG6
Gallery: 17
Hey no problem. I intend to do a tranny service soon. I'll probably take pictures a long the way and make a proper write up. Hopefully I'll beat you to it! haha
__________________
~My '09 2.4 G6~
You may not post new threads
You may not post replies
Forum Jump
service air bag light? asonofabeach69 Problems and Solutions 20 12-23-2012 10:24 AM
transmission replaced and still same transmission problem Sterling Problems and Solutions 7 09-20-2011 04:53 PM
service airbag mekb27 Problems and Solutions 3 08-18-2011 06:53 AM
A/C service, who should do it? Mike18wheels General Maintenance 5 08-25-2009 10:56 PM
Oil Change Intervals PCB General Maintenance 52 07-21-2006 08:17 AM
© AutoGuide
