how do i remove dome light? - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Ľ Wheel & Tire Center
Thread Tools Display Modes
Old 04-30-2009, 07:18 PM   #1
TheGuyz
Gallery: 0
TheGuyz is on a distinguished road
Hi,
I have a 2006 G6 GT and have a broken switch on dome light ( aka door open will not light ).
So I wish to remove dome light and try and fix or replace if needed, but my problem is I can remove the grey outter plastic with lens, but cannot figure out how to remove the back end from roof ( white plastic with switch ). I see no clips or screws.
Any help/suggestions would be appreciated.
__________________
2006 Pontiac G6 GT 2DR Silver
TheGuyz is offline   Reply With Quote
Old 05-01-2009, 12:06 PM   #2
pzwestside
Pontiac Enthusiast
pzwestside's Avatar
Gallery: 0
pzwestside is on a distinguished road
Originally Posted by TheGuyz View Post
Hi,
I had to replace my switch too... believe it or not, there IS clips holding it up.. you have to get your finger in there or a screw driver to pop the clips. there is 5 I believe in a star pattern... just feel around for them and give it a slight push inwards and it should come loose.. there is a metal contact under the switch that is likely broken therefore not lighting the dome up...
__________________
Regards,
Paul
______________________
2006 Pontiac G6 GT Coupe
pzwestside is offline   Reply With Quote
Old 05-05-2009, 08:20 PM   #3
TheGuyz
Gallery: 0
Hi,
Thanks for your reply, I will try loosing for the 5 tabs tommorrow.
__________________
Old 05-06-2009, 01:30 PM   #4
pzwestside
Pontiac Enthusiast
pzwestside's Avatar
Gallery: 0
Hi,
Let me know... remember, not too much pressure or you will break the clips.. just enough to release one part at a time.
__________________
Regards,
Paul
Old 05-07-2009, 05:34 AM   #5
TheGuyz
Gallery: 0
I tried but had to big screwdriver so was worried about clips, gonna try and exacto knife today.
Will let you know.
__________________
Old 05-07-2009, 05:11 PM   #6
TheGuyz
Gallery: 0
Ok not sure if 2 door dome light removal is different but appears it is.
There are 3 big tabs 1/2" by 1/2" so you have to push assemble up and to side then pull one corner down, after top faceplate is remove to remove assemble.
My fix was simple as was just bent contact so i just bent back in place and now opperates as normal ( off, door open, on ).
__________________
You may not post new threads
You may not post replies
Forum Jump
Dome light issue... cbowles Problems and Solutions 11 12-09-2013 03:12 PM
Remove DRM from iTunes AAC M4V M4P M4A on Win and Mac seashell Off-Topics 5 02-01-2011 10:59 AM
2005 G6 Door ajar and dome light on '70 Mach 1 Problems and Solutions 7 04-12-2009 08:55 AM
I need fog light for g6 any options other than dealership? thanks dh08 Problems and Solutions 7 06-30-2008 08:50 AM
Dome Light Wont Completely Turn Off WhoaThereBigFella Problems and Solutions 6 09-28-2006 01:57 PM
© AutoGuide
