Sunroof water leak fix... - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > HOW-TO
Thread Tools Display Modes
Old 06-08-2009, 11:57 PM   #1
maykevin5
GTP 06
maykevin5's Avatar
Gallery: 5
maykevin5 is on a distinguished road
Send a message via MSN to maykevin5
Finaly a how to on fixing leaking sunroof!! Thank you, Thank you
Yep I'm another victim. But instead of having the dealer spend hours working on it, I figured I'd tackle it myself. So after completing the task, it only took about 15 minutes to do and quite easy. Here is a how to guide to help you!
Problem:
1. Get the tools you will need handy. small flat tipped screwdriver and a Phillips screw driver.
2. Locate where the water is coming from, if its coming from the seat belt its probably your rear tubes. if its running down the apiller's its most likely the front tubes. In my case it was the front tube right side.
3. Using your small flat screwdriver gently pry open the screw covers on your visor, apiller and seat belt cover. Remove the screws.
Would have had more pictures, but they limit me to 10
4. you will gently pull out your apiller cover to expose the tube. and remove your visor, careful not to break the wire running your visor lights. "Above Picture"
5. Easily and gently pull out the edge of the liner from the weather seal all the way back to your seat belt cover.
6. Once you have the liner pulled down a little bit you should be able to see in there and see the tube where it hooks up to the sunroof.. Yep that was my issue.
7. Clean the water off the tube and inside the hole. Find some plastic glue or I used superglue and with two fingers reach in there and smear some glue around the tube. Push the tube back in the drain with a little force not too much though. make sure the tube clears the head liner when putting back together. Easly press the liner back over the weather seal back to the apiller. Put screws back in and make sure everything is tight.
Your Done!!
The dealer would have just pushed it back in causing it to come back out with time.. but with glue, you know its going to stay.
maykevin5 is offline   Reply With Quote
Old 06-09-2009, 03:11 PM   #2
maykevin5
GTP 06
maykevin5's Avatar
Gallery: 5
Old 10-21-2009, 11:52 PM   #3
g6man2484
g6man2484's Avatar
Gallery: 21
g6man2484 is on a distinguished road
How do you take off the seat belt?.
g6man2484 is offline   Reply With Quote
Old 11-24-2009, 10:45 PM   #4
Silver Bullet
Gallery: 0
Silver Bullet is on a distinguished road
Okay so I have a question... I have fixed this pipe twice now and it still leaks. I have used silicone and zip ties and still... no success. Now my heated seat isn't working on the side that the tube is leaking on. Has anyone had this problem? Are the heated seats wired into the floorboards?
Silver Bullet is offline   Reply With Quote
Old 12-13-2009, 06:23 PM   #5
maykevin5
GTP 06
maykevin5's Avatar
Gallery: 5
I used superglue not silicone.. No problems after..
Old 01-05-2010, 10:38 PM   #6
Asp
Gallery: 0
Asp is on a distinguished road
I'll have to give this a try. I'm having puddles of water freezing up behind the passenger seat on the floor. Next day off seems like a good day to get down and dirty.
Asp is offline   Reply With Quote
Old 06-12-2013, 01:02 PM   #7
pucho777
Gallery: 0
pucho777 is on a distinguished road
before u go crazy taking ur headliner apart, go into the trunk of ur vehicle where the tubes exit the vehicle pull it out and clean them that was my problem they where clogged once cleaned the water start flowing without a problem, oops forgot to tell u where the tubes are u have one behind the amp on the right side and the other in the other side. very easy to get to. any questions feel free to ask.
pucho777 is offline   Reply With Quote
Old 08-17-2013, 10:05 AM   #8
AnconaGT
Gallery: 0
AnconaGT is on a distinguished road
Pucho what did you use to clean them?
AnconaGT is offline   Reply With Quote
Old 08-17-2013, 11:06 AM   #9
slls
Gallery: 0
slls is on a distinguished road
If I was to do mine, I would add extensions. Local purchase, not dealer.
__________________
09 G6 2.4 Sun & sound package-Preferred package
225/50R17S factory
slls is offline   Reply With Quote
Old 09-21-2013, 03:23 AM   #10
miguelthegr8
miguelthegr8's Avatar
Gallery: 0
miguelthegr8 is on a distinguished road
Thanks so much!
miguelthegr8 is offline   Reply With Quote
Old 06-28-2015, 04:43 PM   #11
callahac
Gallery: 0
callahac is on a distinguished road
Cleaning the tubes seemed to work for me too.
callahac is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Water Leak RedRocket Problems and Solutions 13 11-11-2013 03:44 PM
Bug build-up in front light and leaking water. Asp86 Problems and Solutions 2 04-26-2009 09:55 PM
Advice re: Aftermarket Sunroof ???? GTPCoupeGirl Appearance Modifications and Lighting 7 12-22-2005 07:04 AM
Taking on water.... S8ER99 Problems and Solutions 4 10-03-2005 01:43 PM
Leak from Sunroof Ctrl Panel AND around hood release. jwc194 Problems and Solutions 7 07-25-2005 11:32 AM
© AutoGuide
