I have code P0171 P0300 and P0420 - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 06-24-2009, 09:10 PM   #1
No Box
Gallery: 0
No Box is on a distinguished road
Ok so my engine light came on and my car is now running really bad. It has terrible acceleration but once in am at full speed it is fine. I have a 2006 Pontiac G6 with the 2.4L with 61k miles on it. I am out of warranty except for the Catalytic Converter and the PCM. I really want to trouble shoot this first before I have to bring it to the dealer if it is a converter problem. I took my car to my friends shop to get the code out of it to see what we can do.
P0171 is that the engine is running lean
P0300 is a misfire in two cylinders. (Car does not sound like it is misfiring)
P0420 is Catalyst System Efficiency Below Threshold which means that the Cat converter is not working so great.
I have been doing research on this and other sites say that you need to fix the first codes before you fix the 420 code. The first codes could be causing the 420 to come on. I was also reading that a vacuum leak could cause the misfiring.
I really think it is the Converter the car was making a rattling noise from the exhaust when i started it up in the morning. The noise went away the same day the engine light came on.
Has anyone else had this type of problem? Any help would be appreciated.
No Box is offline   Reply With Quote
Old 07-08-2009, 03:39 PM   #2
No Box
Gallery: 0
Well as a follow up I took my car to the dealer and it was the Catalytic Converter. They replaced it under warranty.
Old 08-23-2010, 09:16 PM   #3
archebald23
Gallery: 0
archebald23 is on a distinguished road
weird, we actually have the same symptoms but mine was because of the sensors. I had the sensors replaced and wala, problem gone.
archebald23 is offline   Reply With Quote
Old 08-23-2010, 09:26 PM   #4
TinIndian
07 Black GT Vert ♥
TinIndian's Avatar
Gallery: 3
TinIndian is on a distinguished road
Check to make sure there are no leaks in the air intake duct that runs from the the MAF sensor to the throttle body.
Add a bottle of Techron to a full tank of fuel and drive it completely out.
__________________
TinIndian is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
© AutoGuide
