Help with Camshaft Position Sensors - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Ľ Wheel & Tire Center
Thread Tools Display Modes
Old 11-12-2009, 11:51 AM   #1
jpopson43
Gallery: 0
jpopson43 is on a distinguished road
Hello, I have a 2007 G6 2.4L. Lately my car has been bogging down with a loss of power, and doesn't seem to shift smoothly. My friend used his scan tool and said the car was throwing a code for a cam sensor. I then find out that the car actually has TWO camshaft position sensors, yet I can only locate the one right on top of the engine under the plastic cover. The parts store I called is telling me there are two on this car, yet can't tell me where they are located. Does anyone know if there are actually two, and if so, where the other is located?? I great appreciate any responses. Thanks!
jpopson43 is offline   Reply With Quote
Old 11-15-2009, 07:55 PM   #2
daygon
Gallery: 0
daygon is on a distinguished road
call the parts department of the local GM dealer
daygon is offline   Reply With Quote
Old 11-19-2009, 04:53 PM   #3
sly fox
Gallery: 0
sly fox is on a distinguished road
Did you ever find out where the second sensor is located? Also does the computer have to have a crankcase relearn when these sensors are replaced? I know on my grand am it has to have one anytime a crank or cam sensor is replaced.
sly fox is offline   Reply With Quote
Old 01-25-2010, 12:24 PM   #4
XLNDRVR
Gallery: 0
XLNDRVR is on a distinguished road
The intake (INT) and exhaust (EXH) sensors are both located side-by-side on the top passenger side of the engine, under the plastic cover.
Replacing the intake sensor eliminated the hard shifting on our 2.4L 2006 G6. Still have a lack of power, though. Engine light is back on, so I need to check codes again to determine next step. Perhaps the exhaust sensor is faulty, as well.
Replacing one of these sensors is a 5 minute job.
XLNDRVR is offline   Reply With Quote
Old 08-05-2010, 09:50 AM   #5
jameschaseoliver
Where is it now???
Gallery: 0
jameschaseoliver is on a distinguished road
Send a message via Skype™ to jameschaseoliver
Where exactly is the camshaft sensor, i think my sensor is giving me problems. Same issues and the code P0011
jameschaseoliver is offline   Reply With Quote
Old 08-05-2010, 10:19 AM   #6
slls
Gallery: 0
slls is on a distinguished road
I read there is a wiring issue with the sensors.
slls is offline   Reply With Quote
Old 09-01-2010, 10:30 AM   #7
mjmike63
Gallery: 0
mjmike63 is on a distinguished road
According to manual 2008 G6 2.4l camshaft position sensors are on drivers side of engine mounted sideways in head with plug extended out towards driverís side. see attached
Click image for larger version
mjmike63 is offline   Reply With Quote
Old 09-10-2010, 07:30 AM   #8
XLNDRVR
Gallery: 0
Follow-up: Cat Conv also needed to be replaced. Remember, by law, emmisions components are covered to 80,000 miles on all cars. Problems resolved.
Old 09-10-2010, 10:22 AM   #9
reverttheclown
reverttheclown's Avatar
Gallery: 0
reverttheclown is on a distinguished road
whats this?
__________________
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline   Reply With Quote
Old 09-11-2010, 08:32 AM   #10
jpopson43
Gallery: 0
It's been awhile, but we had to replace several things to get the car going back to normal again. We replaced both cam sensors, and that didn't fix it! We then took it to the dealer and found out that both the injectors and the catalytic converter were bad. The mechanic told me it was common on these that the injectors clog up and go bad and then make the catalytic converter go bad as well. The injectors were no longer under warranty, but the catalytic converter was. The dealer said they would do it all for free though since it was a known issue with GM. They also replaced my intermediate steering shaft for the SECOND time even though the warranty was up on it. I've had SO many issues with this car before 50,000 miles it isn't even funny!
Old 09-11-2010, 11:05 AM   #11
slls
Gallery: 0
The power train warranty from 2007-2009 include this. 5 year 100K
1) The entire pressurized fuel system (in-tank fuel pump, lines, fuel rail, injectors and return line.
Not included for 2010, your dealer is BSing you.
Old 09-12-2010, 08:33 AM   #12
jpopson43
Gallery: 0
It says right in my owner's manual that the power train warranty is only 5 year, 60,000 miles...and that's what two dealers have told me. Though, I didn't know that the injectors were covered under power train...so apparently they were still covered and they were BSing me...because the car only had like 49,000 when we had this done.
Just out of curiosity where did you find this 100,000 mile warranty info? Only doubting it because, like I said, my manual clearly only says 60,000 for power train.
Old 09-12-2010, 09:59 AM   #13
slls
Gallery: 0
Here is where I got it. Both are good reads.
http://www.leftlanenews.com/general-...-warranty.html
http://www.thetruthaboutcars.com/gm-...year-warranty/
Old 09-13-2010, 10:26 AM   #14
jpopson43
Gallery: 0
Oh ok, so it seems that this is something that GM released after I purchased my car, and it will roll back and be active on my car. Thanks for the information...and that's awesome to know that the dealer was bullshitting me!
Old 09-14-2010, 10:00 AM   #15
slls
Gallery: 0
Glad to help. Just remember, google is your friend.
You may not post new threads
You may not post replies
Forum Jump
Relearn my camshaft! NySwat Powertrain Performance Modifications 1 10-01-2009 05:40 AM
install new tire sensors? mreaglejr Handle It! - Suspension, Wheel and Tire Modifications 5 06-14-2009 02:11 PM
Tire sensors ryansg6 Handle It! - Suspension, Wheel and Tire Modifications 10 06-01-2009 08:17 PM
Ruber valve stems with TPMS (tire sensors) bri2203 Handle It! - Suspension, Wheel and Tire Modifications 3 11-30-2008 08:33 AM
Camshaft Problem cdsipjp Problems and Solutions 4 02-25-2008 10:38 AM
© AutoGuide
