Brakes keep sticking on - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 12-13-2009, 09:16 AM   #1
2strokejunkie
Gallery: 0
2strokejunkie is on a distinguished road
I just bought a 2005 G6 with 98,000km on it and the last few weeks the brakes keep sticking on.My wife came home and there was smoke coming from the front brakes.Then we are on the highway a week later and they lock up,car starts vibrating and shacking like i blew a tire.I get out and nope all is good,lug nuts are good,tire pressure.So i call my brother a mechanic and he says to pump the brake pedal hard.So i did 5-6 times and then drove away and it was good.Ten minutes later they lock up again and i cant get over 15km/hr.He thinks the sensor is coming out of adjustment maybe?also sometimes the command start wont work and it seems like it sences that the brake is on..so maybe it needs adjustment on that sensor.Im going to check the brake lights to see if they are working right after reading the issues on here and wonder what kinda car i bought...
2strokejunkie is offline   Reply With Quote
Old 12-13-2009, 11:34 PM   #2
markpetersonii
Gallery: 10
markpetersonii is on a distinguished road
Send a message via AIM to markpetersonii Send a message via MSN to markpetersonii
Sadly, I think you should take it in... Though I think you're out of warranty. Do you have extended?
__________________
2003 Mercedes Benz E500 Sport - 2001 Ford Ranger XLT
markpetersonii is offline   Reply With Quote
Old 12-14-2009, 07:12 AM   #3
2strokejunkie
Gallery: 0
Nope no warranty but my brother is a mechanic so we are gona look at it.I think im gona replace all rotors and pads and maybe even calipers...Is there a brand that anyone recommends to replace with....thxs
Old 12-14-2009, 07:29 AM   #4
Lampoon
Gallery: 40
Lampoon is just really niceLampoon is just really niceLampoon is just really niceLampoon is just really nice
Rotors are warped. Replace them. Surprised they lasted as long as they did.
I replaced mine with R1 Concepts & Akebono ceramic pads at 45,000 miles.
Im currently at 103,000 miles and they are still working like a champ.
__________________
Lampoon is offline   Reply With Quote
Old 12-15-2009, 10:05 PM   #5
markpetersonii
Gallery: 10
If they are sticking then they are SEVERELY warped! Mine are right now and I just ordered Cquence Rotors and ceramic pads. Should have them tomorrow!
__________________
Old 12-16-2009, 05:22 AM   #6
Lampoon
Gallery: 40
Lots of Complaints on the other board about clicking with those.....let us know how they work out.
__________________
Old 12-22-2009, 12:13 AM   #7
markpetersonii
Gallery: 10
Yeah, I will def let you know! Military Snail Mail... I should have them tomorrow... HOPEFULLY!
__________________
Old 12-25-2009, 10:47 PM   #8
2strokejunkie
Gallery: 0
Well my fluid level was 1/2" higher than it should be and the front rotors are scored and flaky...so im doin rotors around and hope its good to go...
Old 12-26-2009, 09:00 PM   #9
D-06v6g6
Gallery: 0
D-06v6g6 is on a distinguished road
Just read your thread. First thing to look at when brakes seem to be sticking, is to lift the lid on the brake fluid reservoir. The rubber on the back of the lid should be nice and firm. If it is, that's great. But if it is droopy, then some one has added a petroleum product such as power steering fliud. That would cause all rubber in the brake system to swell, blocking off the flex hoses and holding the brakes on. This doesn't happen very often, but when it does, all parts with rubber in them will need to be replaced. That would be master cylinder, ABS components, rubber flex hoses at the wheel, calipers, etc. I hope this is not your case! Some times sticking brakes can be the 'sliders' seized at the calipers. Good Luck.
D-06v6g6 is offline   Reply With Quote
Old 12-26-2009, 09:11 PM   #10
MattInSoCal
Professional geek
Gallery: 0
MattInSoCal is on a distinguished road
Anti-lock or Traction problem?
Stoopid double-post.
MattInSoCal is offline   Reply With Quote
Old 12-26-2009, 09:14 PM   #11
MattInSoCal
Professional geek
Gallery: 0
Anti-lock or Traction control problem?
Are the brakes sticking only after you apply them, or do they also seem to come on by themselves? Do they seem to be stuck harder than you thought you may have appplied them? Besides the possibility of the pistons sticking in the caliper, it could also be a malfunction in the Anti-Lock Braking or Traction Control modules.
~ MattInSoCal
Old 12-29-2009, 12:05 PM   #12
markpetersonii
Gallery: 10
~ MattInSoCal
OT but where in SoCal are you?
__________________
Old 12-29-2009, 01:04 PM   #13
jetmech_5
Gallery: 3
jetmech_5 is on a distinguished road
That's bad!
Sound like the pads were wore all the way down. I would suggest buying the R1 concept rotors as Lampoon suggested.
DO NOT buy autozone, o'riely or advanced auto parts break pads. Go to Napa, GM or a reputable race break pad.
Also be sure to lube the guides on the caliper with a good high temp break lube. otherwise you will have same problem with breaks sticking later on as the calipers will not be able to slide properly.
jetmech_5 is offline   Reply With Quote
Old 12-29-2009, 01:06 PM   #14
MattInSoCal
Professional geek
Gallery: 0
Where in the world?
Lake Forest in south Orange County, though I'm sitting in the GF's living room in Escondido at the moment. I waved hi as I drove through Oceanside last night, did you see me?
Returning back to the topic at hand, it's not likely to be the pads and rotors as the cause of the sticking, though due to the lockups they may need machining and/or replacing. If the problem is because the pistons are hanging up in the calipers then you might want to think about replacing them, and possibly having the brake fluid flushed. The pistons would hang up either due to a bad seal in the caliper (possibly from someone not properly retracting the piston on a previous brake job) or sediment.
~ MattInSoCal
Old 01-09-2010, 11:50 AM   #15
MattInSoCal
Professional geek
Gallery: 0
Well?
So......
Is it fixed yet? Did you find the actual problem? All us armchair quarterbacks want to know!
~ MattInSoCal
You may not post new threads
You may not post replies
Forum Jump
Noise brakes? Scooter63 General Maintenance 1 11-26-2009 06:56 PM
Slow Sluggish Acceleration and sticking in gear showroomdetail Problems and Solutions 2 11-06-2009 08:54 PM
Brake Squeaks....Pad Sticking? Robby1870 Problems and Solutions 1 06-29-2009 08:44 AM
brakes deadman Problems and Solutions 8 07-28-2006 08:58 PM
Noisy Brakes GJS Problems and Solutions 9 04-25-2006 09:16 PM
© AutoGuide
