Thermostat Location - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > General Maintenance
Thread Tools Display Modes
Old 01-09-2010, 12:59 PM   #1
canetherton
Gallery: 0
canetherton is on a distinguished road
Exclamation Thermostat Location
I am about to change the thermostat on my wifes G6 GT with the 3.5 V6. I need yto know the exact location of the thermostat. I think it is on the hose coming from the radiator on the driver side of the eng directly under the intake. Am I right?
canetherton is offline   Reply With Quote
Old 01-15-2010, 05:36 PM   #2
canetherton
Gallery: 0
Yes it is the hose that is directly under the intake on the driver side.
Old 01-15-2010, 05:54 PM   #3
Lampoon
Gallery: 40
Lampoon is just really niceLampoon is just really niceLampoon is just really niceLampoon is just really nice
Look through your front grill on the drivers side. See it?
__________________
Lampoon is offline   Reply With Quote
Old 12-08-2011, 07:19 AM   #4
nickya0721
Gallery: 0
nickya0721 is on a distinguished road
It is the hose on the bottom of the passenger side of the radiator that is short and goes right into the bottom of the engine. There should be a housing the hose is connected to with two 10mm bolts on it when you take them off the thermostat will be in there. I just changed mine. If you have any questions let me know
nickya0721 is offline   Reply With Quote
Old 11-14-2013, 10:45 PM   #5
Highonchai
Highonchai's Avatar
Gallery: 0
Highonchai is on a distinguished road
Question
How did you get to the bottom bolt on the inlet housing?
__________________
Highonchai is offline   Reply With Quote
Old 11-15-2013, 10:59 AM   #6
nickya0721
Gallery: 0
I believe with an open end 10mm wrench or deep 10mm socket. I had to change mine again and it is easier to remove the passenger headlight that way you have more room.
Old 12-03-2013, 01:11 PM   #7
Highonchai
Highonchai's Avatar
Gallery: 0
Removing the headlight does give plenty of access. Was able to use a universal socket to pop it loose. Thanks for the tip!
p.s. Removing the headlight is a job in itself. Grab a 16" or longer flathead to pop the ball & socket attachment inside the fender and add some grease to the ball before reassembling.
__________________
Old 08-07-2015, 10:18 AM   #8
09PerformRed
Gallery: 0
09PerformRed is on a distinguished road
So which side is it on, the driver or passenger? And that headlight removal is a PITA, is there a better way to get to the thermo?
09PerformRed is offline   Reply With Quote
Old 08-07-2015, 10:22 AM   #9
Lampoon
Gallery: 40
Ok....are you talking about the thermostat that regulates coolant or the one that displays the temp on your DIC?
Old 08-08-2015, 10:07 AM   #10
09PerformRed
Gallery: 0
The one that regulates coolant. My fans run constantly, because the thermostat doesn't allow the temperature of the engine to reach the desired level. I think I said that right. Anyways, I need to replace it, and was also wondering if driving it this way will do damage to the engine prior to getting it fixed.
Old 08-12-2015, 09:20 AM   #11
Lampoon
Gallery: 40
Ive replaced mine twice. its right there under and forward of your TBI. Its easier if you remove your intake tube there. Two bolts and its in your hand. Easy cheesy. I took pix last time I did it but I dont know what I did with em. lol
I can snap more pix if you really need em....but follow the coolant hose.
__________________
Old 08-13-2015, 05:26 PM   #12
09PerformRed
Gallery: 0
If it's not too much trouble, I'd appreciate the pics. Not really a hands on type of guy, but if it's really as easy as you say, will give it a go. Also, will driving it cause further problems, prior to getting it replaced? Thx for the reply.
Old 09-03-2015, 04:10 PM   #13
509_G6
Gallery: 0
509_G6 is on a distinguished road
This is something i'm gonna do in October, right before it starts to get cold here. It's usually one of the first things I do to any used car/truck I purchase.
509_G6 is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Need Help With Changing thermostat RobMadison Problems and Solutions 2 12-08-2011 07:24 AM
Thermostat Change Swollandhis08G6Spot Problems and Solutions 5 12-17-2009 08:18 AM
2006 G6 Thermostat change clearlight Problems and Solutions 1 04-26-2009 10:03 AM
Location HoodHicka Members' Rides 0 05-01-2008 11:55 AM
Location of thermostat on 2000 Firebird highwayprowlerz GMOC Archived Threads 2 12-02-2006 09:37 AM
© AutoGuide
