service air bag light? - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 01-23-2010, 03:21 PM   #1
asonofabeach69
Gallery: 0
asonofabeach69 is on a distinguished road
My wife called me and said that this light has illuminated on the dash, I have never heard of a serivce air bag light before. I really wouldnt know were to begin with this one, has anyone had any experience or issues involving this before? i replaced the battery on tuesday and since then have had stupid issues with the car, i had to take a part of the intake off to due the battery so of course the engine light came on for p0171 and p0174 and now this with the air bag light.
__________________
2006 GTP 3900v6-Tuned for more fun!
2006 GT 3500v6-The old man
2006 GTO LS2
1997 GP GTP L67
asonofabeach69 is offline   Reply With Quote
Old 01-23-2010, 08:43 PM   #2
asonofabeach69
Gallery: 0
update
She has now stated to me that an alert about the airbag came up on the radio (DIC) but it has not popped up since this morning so i'm really not sure what to make of all this.
__________________
2006 GTO LS2
1997 GP GTP L67
Old 01-24-2010, 08:46 AM   #3
KB G6
KB G6's Avatar
Gallery: 0
KB G6 is on a distinguished road
I had a service air bag come on when I first bought it ( I think they cleaned under the hood before they sold it to me) but haven't had a problem since. It's probably no biggie unless it comes back and stays on for more than a day or two.
__________________
Keith
2005 G6 GT
K&N drop-in filter, Pennzoil Platinum 5W-30, 50% tint all around, other than that completely stock
SOLD 11/20/2010
KB G6 is offline   Reply With Quote
Old 11-18-2011, 05:44 AM   #4
geo2823
Gallery: 0
geo2823 is on a distinguished road
my light comes on stays on for 20 minutes goes away for a couple of days then comes back ? took the car back to the shop and of course light does not come on for them. NO CODES (not a GM dealership) Pick it up as soon as I start the car there it is ?
geo2823 is offline   Reply With Quote
Old 11-18-2011, 01:59 PM   #5
greenman
Gallery: 0
A dealer might try re-zeroing the seat sensor. Doing anything on that system requires a tech 2.
Old 11-18-2011, 07:09 PM   #6
mekb27
mekb27's Avatar
Gallery: 0
mekb27 is on a distinguished road
I had that issue and it was a persistant issue at that. The dealer had to zero a sensor but it coming back. They said that they would have to replace the Senor and it was going to be close to 1000 bucks. And that is if it was just one sensor....
__________________
Had a 07 GTP coupe, traded in for my GTI....
mekb27 is offline   Reply With Quote
Old 11-18-2011, 09:05 PM   #7
greenman
Gallery: 0
The seat cushion & the sensors are an integrated unit. The whole smash gets replaced. I have seen the cushion/sensor assy for $400 online, so that dealer's price seems pretty outrageous. I believe you can replace the assy yourself but you would still have to have a dealer re-zero it after install.
Here's more than you probably care to know about the PPS:
__________________________________________________ ___________________
Passenger Sensing System
Here are some tips on the Passenger Sensing System on these vehicles:
- Grand Prix
- LaCrosse/Allure
- Malibu
- G6
- Aura
- Vue
- Ion
How the System Works
The main function of the Passenger Sensing System (PSS) is to determine whether to turn the right front passenger airbag ON or OFF, based on the occupant's size and weight.
For additional information, a streaming video from the GM Training website is available. Click Web Video Library from the main menu, then Technical, then do a key word search on Occupant. The course, 22048.40V - Occupant Safety Systems, will be at the top of the list. You can also call 1.800.393.4831 to order a copy of this video.
Flashing Codes and Re-zeroing Process
The diagnostic trouble code (DTC) information for the Passenger Sensing System (PSS) can be retrieved with the Tech 2 tool and displayed through the passenger airbag status display(fig. 26).
This system displays only B0081 or B0092 on the Tech 2. To access detailed diagnostic codes, follow the SI instructions for flashing DTCs.
The Tech 2 command sequence takes a total of 10 seconds to transmit, during which the status display will change its illumination intensity level according to the pattern defined for that sequence.
If the PSS receives the command successfully, it will command both telltales to full illumination for 1 second, then turn them off for another second.
Then it will display the most significant digit of the DTC by commanding the OFF telltale to flash for a number of times representing the digit.
After the most significant digit has been displayed, the system will display the least significant digit by flashing the ON telltale.
For example, DTC 36 will flash the ON telltale 3 times, then the OFF telltale 6 times.
Digit
Most
Least
Code
Telltale
ON
OFF
If the DTC is active (the condition that created the fault is still present), the code will be displayed two consecutive times.
If the DTC is a history code (the fault condition is no longer present), the code will be displayed only once.
The system will display all active codes first, then the history codes.
The DTCs are defined as follows:
DTC No.
Description
Possible Cause
32
Re-zeroing Fault
At the time the re-zeroing attempt was made:
1. The seat was not empty
2. Other active DTCs were present in the system
34
Wet Fault
The seat is (or was) wet, possibly due to fluid spill
36
Communication Fault
1. Communication error
2. Low battery voltage
3. Wiring harness problem
52
Seat Heater Fault
Seat heater element broken / not grounded
56
System Fault
1. Sensor problem
2. Wiring harness problem
3. ECU component problem
Generally, if the PSS has history codes only and no active codes are currently set, there is no need to replace the system. The history codes still need to be cleared through the Tech 2 tool, and appropriate electrical tests and visual inspections must be conducted in order to ensure that there is no intermittent problem.
After installing a PSS service kit, the system needs to be re-zeroed using the Tech 2 tool. This will update the empty seat reference values stored in the ECU and ensure proper system performance.
TIP: As a preventive measure that enforces re-zeroing after its installation, the service kit comes with an active DTC set. If the codes are checked before the system is re-zeroed, a DTC56 will be displayed. This code will stay active until the system is re-zeroed successfully.
After the PSS recognizes the re-zeroing command, there are two scenarios:
1. If the system classifies the current seat condition as Empty, it will update the reference values and illuminate both airbag status telltales for a period of 10 sec.
2. If the system detects that the seat is not empty or a DTC condition exists, it will command both telltales to alternatively illuminate from off to full illumination in 1 second intervals for a duration of 5 seconds.
In addition, a DTC 32 will set to indicate that the re-zeroing process has failed.
IMPORTANT:
1. If the system fails to re-zero, resend the zero command and follow the instruction above at least three times.
2. During the re-zeroing process, the seat must be empty of any objects and the clearance specified in the service manual must be observed.
Wet Seat
The PSS diagnostic algorithm includes continuously monitoring for a wet seat condition.
A fluid spill on the seat, in particular if the amount is greater than 200 ml, can affect performance and the system may not be able to correctly classify the passenger. For this reason, the PSS sets a DTC34 and defaults to airbag suppress classification.
TIP: Depending on the fluid amount and its distribution after it penetrates the seat cushion, the system may also set a DTC56.
If these codes (34 and 56) are set, the seat cushion assembly must be removed and allowed to air-dry for about 48 hours. After this period the cushion has to be re-installed again and the DTCs checked.
If no active DTCs are present, the history DTCs must be cleared and the system re-zeroed. In this case, no replacement is necessary.
If there are still active codes after the seat is dry, the PSS cushion and module assembly must be replaced.
IMPORTANT: Replace the parts as a set. Cushion and module must not be separated, because they were calibrated as a pair.
Old 11-19-2011, 05:47 AM   #8
geo2823
Gallery: 0
thanks I will see, if I can get it check out at the Dealer
dealer check no codes they did no say they rezero hold me $1100 to maybe fix the problem
Old 02-01-2012, 09:14 PM   #9
wolvesh
Gallery: 0
wolvesh is on a distinguished road
i have same problem
wolvesh is offline   Reply With Quote
Old 02-01-2012, 11:58 PM   #10
greenman
Gallery: 0
You'll soon find out why they call it the thousand dollar light.
Old 02-02-2012, 05:43 AM   #11
geo2823
Gallery: 0
Old 02-02-2012, 03:29 PM   #12
reverttheclown
reverttheclown's Avatar
Gallery: 0
reverttheclown is on a distinguished road
that is brilliant....too bad i have this light but its the passenger sensor.
__________________
2006 Pontiac G6 V6 3500L
Crimson Red
reverttheclown is offline   Reply With Quote
Old 09-26-2012, 12:40 PM   #13
themrs1
Gallery: 0
themrs1 is on a distinguished road
I am having the same problem with my driver airbag light, it has been fine since I had them check it like 3 weeks ago,now it just came back on again today. Also, the passenger airbag/seatbelt light does not reigster when there is someone in the seat. Sometimes it will work for like a few seconds, then it will say "off" again. Does it mean that something is wrong with the airbag (it wont deploy) or is it just a sensor that I should not be worried about?
themrs1 is offline   Reply With Quote
Old 09-26-2012, 01:29 PM   #14
greenman
Gallery: 0
So what did they do when you had it in?
The only way to know is to get the airbag codes read. Either a dealer or a shop with an air bag code reader.
The passenger airbag will not deploy if the system does not register a passenger's presence. You need to get the codes read.
There is a bulletin out for the airbag system:
Bulletin No.: 08-09-41-002E
Date: December 07, 2009
Subject: Diagnostic Information for Supplemental Inflatable Restraint (SIR) System, Intermittent AIR BAG Indicator/Lamp Illuminated with DTC(s) B0012, B0013, B0015, B0016, B0019, B0020, B0022, B0023, B0026, B0033, B0040, B0042 or B0044 Set (Inspect and Replace Connector Position Assurance (CPA) Retainer)
Models:
2005-2007 Buick Rainier
2006-2009 Buick Allure (Canada only), LaCrosse, Lucerne
2008-2010 Buick Enclave
2006-2010 Cadillac DTS
2007-2010 Cadillac Escalade Models
2008-2009 Cadillac SRX, XLR
2008-2010 Cadillac CTS, STS
2005-2006 Chevrolet SSR
2005-2009 Chevrolet TrailBlazer, TrailBlazer EXT
2005-2010 Chevrolet Cobalt
2006-2007 Chevrolet Monte Carlo
2006-2010 Chevrolet Corvette, HHR, Impala, Malibu Models (includes Malibu Classic)
2007-2009 Chevrolet Equinox
2007-2010 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2008-2010 Chevrolet Express
2009-2010 Chevrolet Traverse
2005-2009 GMC Envoy Models
2007-2010 GMC Acadia, Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2008-2010 GMC Savana
2005-2006 Pontiac Pursuit
2005-2009 Pontiac G6
2006-2009 Pontiac Solstice
2007-2009 Pontiac G5, Torrent
2008-2009 Pontiac G8
2005-2009 Saab 9-7X
2007-2009 Saturn AURA, OUTLOOK, SKY
2008-2009 Saturn VUE
2008-2009 HUMMER H2
2007-2008 Daewoo G2X
2007-2009 Opel GT
Supercede:
This bulletin is being revised to update the Parts Information. Please discard Corporate Bulletin Number 08-09-41-002D (Section 09 - Restraints).
Condition
- Some customers may comment on an intermittent or current AIR BAG indicator or lamp being illuminated on the instrument panel cluster (IPC).
Important
This bulletin only applies to the following DTCs:
- Technicians may observe DTC(s) B0012 04, 0D, 0E; B0013 04, 0D, 0E; B0015 04, 0D, 0E; B0016 04, 0D, 0E; B0019 04, 0D, 0E; B0020 04, 0D, 0E; B0022, B0023 04, 0D, 0E; B0033 04, 0D, 0E; B0040 04, 0D, 0E; B0042 or B0044 set as Current or in History in the sensing and diagnostic module (SDM).
Cause
This condition may be caused by a loose, missing, or damaged connector position assurance (CPA) retainer at a supplemental inflatable restraint (SIR) module electrical connector, or a deployment loop wiring harness electrical connector.
Correction
Caution
When performing service on or near the SIR components or the SIR wiring, the SIR system must be disabled. Failure to observe the correct procedure could cause deployment of the SIR components. Serious injury can occur. Failure to observe the correct procedure could also result in unnecessary SIR system repairs.
1. Perform the Diagnostic System Check-Vehicle.
2. Identify the DTC that is set AND review the DTC Descriptor in the corresponding diagnostic procedure. Refer to Diagnostic Trouble Code (DTC) List-Vehicle in SI.
3. Using the information from the DTC Descriptor, determine the location of the affected electrical connector. Refer to SIR Identification Views and the Master Electrical Component List in SI.
4. Turn OFF the ignition and disable the supplemental inflatable restraint (SIR) system. Refer to SIR Disabling and Enabling in SI.
5. BEFORE removing, INSPECT the CPA retainer at the electrical connector.
Note
The connector and connector position assurance (CPA) may seat independent of each other. Both the connector and CPA should seat with an audible and/or tactile click. The CPA isolates the shorting-bars within the connector allowing the deployment circuit to operate properly.
If the CPA retainer is loose, damaged, or will not seat in the connector, replace it with a new one. Reinstall the CPA correctly by first pushing the connector body in completely, and then pushing the CPA retainer in completely.
If the CPA retainer is not loose or damaged and is properly seated, proceed to Step 6.
6. Remove the CPA retainer and disconnect the electrical connector. Inspect the terminals for the following conditions:
- Corrosion
- Contamination
- Terminal tension.
- Damage
Important
The terminals in the SIR/SRS system are made with a special plating. This plating provides the necessary contact integrity for the sensitive, low energy circuits. Use the J-38125 SIR/SRS Terminal Repair Kit for repairing SIR/SRS terminals and connectors. DO NOT substitute any other terminals for those in the repair kit.
If the terminals are damaged, corrosion is observed, or have poor tension, repair or replace as necessary. Apply dielectric grease, GM P/N 12345579 (in Canada, use P/N 10953481) on the connector pins and terminals when reassembling. Refer to SIR/SRS Wiring Repairs in SI.
Note
7. Connect the electrical connector, and install the CPA retainer.
8. Enable the supplemental inflatable restraint (SIR) system. Refer to SIR Disabling and Enabling in SI.
9. Clear the DTC with a scan tool.
10. Verify that the DTC does not reset by performing the Diagnostic Repair Verification in SI.
If any DTC resets, then refer to Diagnostic Trouble Code (DTC) List-Vehicle in SI.
Old 09-26-2012, 03:02 PM   #15
2010G6BaseMan
Gallery: 0
2010G6BaseMan is on a distinguished road
Mine comes on a lot... I found that is in the seat like stated in an above comment, for me its the drivers seat. I found that when I sort of bounce my butt in the seat to add pressure, the light turns off and will tend to stay off until I get up or move a lot like digging out my wallet. I'm sure its just from being worn down from all of the 10 hour drives I have done but nothing serious try the butt bouncing thing.. it might work :/
2010G6BaseMan is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Cnvt. airbag service light issues j1biggs Problems and Solutions 3 12-02-2011 09:12 PM
air bag problems nickkendall Problems and Solutions 0 05-03-2009 08:59 PM
`07 Air Bag Light On Lager&Ale Problems and Solutions 4 04-25-2008 10:48 PM
Air Bag Question WhoaThereBigFella Car Audio, Video and Security 2 09-06-2006 07:58 PM
© AutoGuide
