This was very helpful. I had gotten to the point of trying to pull the headlight assembly out. I really thought I was a going to rip my assembly apart because the assembly was in there so hard. Your note at least gave me a sense that it would come out. Thanks it is done! If anyone tries it, it will require some patience because you would think the design would be simpler. Afterall, it is a bulb.
The first time I changed the bulbs the car was 5 years old and it took an hour to get those lights to pull out of the ball and socket joint. It was just old, dirty, and stuck. Having someone to pull back the fascia helps. There really is not trick. But I can tell you that I covered the joint with vaseline and the next time I had to change the bulbs the headlamp assembly pulled right out.
The AutoGuide.com network consists of the largest network of enthusiast-owned enthusiast-operated automotive communities.
AutoGuide.com provides the latest car reviews, auto show coverage, new car prices, and automotive news. The AutoGuide network operates more than 100 automotive forums where our users consult peers for shopping information and advice, and share opinions as a community.
