Tools Needed for Replacing Front Brake Pads and Rotors? - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > General Maintenance
Thread Tools Display Modes
Old 10-08-2010, 09:42 AM   #1
goufcustom
Gallery: 0
goufcustom is on a distinguished road
Question Tools Needed for Replacing Front Brake Pads and Rotors?
I have a 2007 Value Leader 2.4L G6 Sedan with 75k miles and it is time to replace the brake pads and rotors. I have already bought some EBC Rotors and Pads to match, and plan to do the install myself with a friend.
Assuming I have no tools at all, what tools do I need to have on hand to make this as painless as possible and of course to do it right. I only plan to do the fronts at the moment, may replace the back if I continue to have issues.
I found something here about a Borg Tool: ...?
http://www.g6ownersclub.com/forum/showthread.php?t=5624
My friend mentioned something about needing a clamp and/or some brake pushing tool.
I will have a Torque Wrench, are the published specs on what to torque the rotors to? I will also have some generic tools to get the car in the air, and sockets and the like, the really common stuff.
Is there a manual or something?
As you can probably tell this is my first brake replacement, in my defense I am a younger member, but I have no worries because I am a very technical person.
If there is a post about this a link will work too, but most of the threads I have found are just comments on what pads/rotors are good, I dont plan on returning mine, and if they are "s**t" by your standards then keep it to yourself please.
goufcustom is offline   Reply With Quote
Old 10-08-2010, 10:05 AM   #2
filian
filian's Avatar
Gallery: 15
filian is on a distinguished road
all thats needed are sockets with ratchet,c-clamp is what you'll need, car jacked up, there are only 2 bolts holding the caliper on to get to the pads. Then there are 2 bolts holding the brake pad bracket on. once the brackets off you can take the rotor off. the c-clamp is to compress the cylinder in the caliper in all the way. I recomend you use brake lube on the pad contact areas of the brake pad bracket. also use brake cleaner on the rotors & calipers after new install. good luck
filian is offline   Reply With Quote
Old 10-13-2010, 06:16 AM   #3
goufcustom
Gallery: 0
Well I was able to replace all the pads and rotors, and then took it to a shop to have the lines flushed. Total was ~$430 for EBC pads and rotors on the front, Advanced Auto parts on the rear, and a flush from Goodyear, plus a few beers for my neighbor that lent me his jack.
I needed, and your experience may vary...
-Sockets and Wrench, 50/50 metric and standard
-Needle Nose Pliers (to turn the rear piston)
-Jack and Stands
-Flat Head Screw Driver
-Rubber Mallet
-C-Clamp (to compress the front piston)
-Grease
-Brake Cleaner
-Tooth Brush (to scrub some dirty parts)
-Jack Hammer with Jaws of Life Add On (to remove the lock washers on the old rotors)
-Beer
Old 10-13-2010, 06:26 AM   #4
geewhiz
Lifetime Member
geewhiz's Avatar
Gallery: 9
geewhiz is on a distinguished road
Thanks for the up-date, I plan to do the brakes on mine in a month or so. Depending on my mood I might take pics and add a little write up.
I'm changing the brakes on the Pinto first (of course you won't need a write on that here!).
__________________
Mike
MODS;
None, if I want a faster car I'll buy one.
geewhiz is offline   Reply With Quote
Old 10-14-2010, 06:15 AM   #5
goufcustom
Gallery: 0
Cool
I was thinking of doing a write up with some pictures but then I got lazy, sorry...
Specific to a 2007 G6 VL 2.4L, you experience may vary.
But once you get the tire off, and the car in the air, you can spray the bolts on the calipers and pad holder with WD-40 to help them out a little.
Remove the bolts on the caliper and use a flat head to pry it forward and off, then you can pop the pads out. I think these were 13mm
Remove the bolts on the pad holder and pop that out, you will want to remove the bent peices of sheet metal on either side, carefully, and clean them and re-install them. They only go on one way but be careful.
Remove and lube the piston like things on the pad holder, make sure the dust covers are back in place and they should move freely once installed, ie puch down on them and they should quickly and smoothly pop back.
Remove, if you can the lock washers on the rotor. Then you can take the old rotor off and put the new one on. I was told not to touch the braking surface.
Now you can reinstall the new rotor, and then the pad holder, put all the bolts back in and make sure the small peices of sheet metal are on and correct.
NOTE: You could put new lock washers on, as I distroyed mine and once I got them off I through them across the yard, cursing them. You dont need them...
On the pads, use the old ones as a reference, install the travel stop should be one stop on each side of the car, so on 2 out of the 4 pads, I think it goes on the inside one. Use the ones you removed as a reference.
Use a C-Clamp and the old pad to push the caliper piston back in, be careful of the dust cover boot around the piston make sure it is even and almost flush, otherwise you will burn the boot while driving on it. It is not a function critical part, but it keeps dirt out of the system. Remove the C-Clamp and slide the caliper over the new pads. Bolt her down.
Reinstall the tire and do it all over again.
Differences in the rear job.
Same bolts and smaller pads and rotors, but it all looks the same, and the order is all the same.
Big difference is you need to have the parking brake OFF, and chock your wheels! You should chock your wheels anyway. Instead of using the C-Clamp to compress the rear pistons, use a set of needle nose plyers to turn (righty tighty) the piston into it self, it is very easy.
Finally a test drive with a curb (end of drive way) warrenty.
I also highly recommend the brake line flush, I had it done as I hear it is a dirty pain in the @$$ job. The rotors and pads made the ride more comfortable, and the flush took the 1" of travel out of the brake pedal before something happened. Overall it was well worth the money.
Old 10-14-2010, 11:00 AM   #6
hndah8r
A BANNED TERD
Gallery: 0
hndah8r is infamous around these parts
The best how to imho, and the one i used...
http://www.g6performance.com/forum/s...?t=8305&page=4
hndah8r is offline   Reply With Quote
Old 10-14-2010, 07:52 PM   #7
goufcustom
Gallery: 0
Yep, that works and that is exactly what I did.
You may not post new threads
You may not post replies
Forum Jump
Need help with replacing rear brake pads g6gt2005 Handle It! - Suspension, Wheel and Tire Modifications 5 06-14-2010 08:49 AM
I really want to upgrade my pads & rotors but... Earl Flynn General Maintenance 3 05-24-2010 12:24 PM
New Rotors & Pads at 35,000 KM brilliantrewards Problems and Solutions 1 07-09-2009 05:49 AM
Best Brake Pads and Rotors to Buy stephcorleone General Maintenance 10 01-12-2009 06:44 AM
© AutoGuide
