no lowbeam headlights - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 02-08-2011, 11:08 AM   #1
doublej80
Gallery: 0
doublej80 is on a distinguished road
My girlfriend has a 2006 Pontiac g6 gtp. This weekend I noticed that at some point her headlights weren't working. My first thought was that I had turned off the automatic running lights by accident. Once I verified that the auto lights were on, but we still had no headlights, I tried to manually turn on the headlights. Once again, I found that we had no lights. We were driving at night at the time so I had to ride home with the high beam lights on. The high beam lights work fine, as do the side marker lights, but no low beam. I'm wondering if anyone else has had this happen and where should I be looking to troubleshoot the problem. Thanks in advance.
doublej80 is offline   Reply With Quote
Old 02-08-2011, 11:58 AM   #2
waterfowler76
Gallery: 16
waterfowler76 will become famous soon enough
fuses??? check number 7 and 9 in the fuse box under the hood.... or maybe both bulbs burnt out at the same time... odd but not impossible.
__________________
Waterfowler's 6
waterfowler76 is offline   Reply With Quote
Old 07-27-2011, 03:27 AM   #3
Caper10
Gallery: 0
Caper10 is on a distinguished road
We are having the same problem ... did you get it resolved and what was the solution
Caper10 is offline   Reply With Quote
Old 07-27-2011, 12:45 PM   #4
greenman
Gallery: 0
Low beams only affected as in the original post?
Very possible a bad multifunction switch but without circuit testing its impossible to know. First try swapping the low beam relay out with another (with the same number) in the engine fuse block & see if any joy to be had there. Each side is fused individually so I doubt both fuses are open. But check them anyway. What year is that vehicle?
Old 08-08-2011, 05:24 AM   #5
Caper10
Gallery: 0
Both low beam bulbs burnt out.... first time for that one...no more cheap ebay bulbs for me
Old 08-14-2011, 04:47 PM   #6
g61
Gallery: 0
g61 is on a distinguished road
same issue got a 05 g6 base model got a problem with my headlight every now and then when i go over a bump my passenger side drl ligh cut in and out signal wrks fine high beam wrks fine but the low beam keeps cuttin in and out in the fuse box the low beam relay is braced with a piece of styrfoam friggin guy who sold it to me never told me about it if i take the styrfoam out both headlighs low beam won't wrk. Please help me.
g61 is offline   Reply With Quote
Old 08-14-2011, 07:10 PM   #7
greenman
Gallery: 0
Have you tried pulling the relay & spraying the slots good with electrical contact cleaner spray & swapping the relay with another known good one?
Old 08-14-2011, 10:08 PM   #8
g61
Gallery: 0
Headlight
i will try cleaning it with some cleaner asap the realy is good
will let you know if it wrks thanks
Old 08-19-2011, 05:23 PM   #9
g61
Gallery: 0
cleaning realy slots
will wd 40 work?
Old 08-19-2011, 06:49 PM   #10
greenman
Gallery: 0
will wd 40 work?
Absolutely not. Only use electrical contact spray cleaner available at any parts house, hardware, most variety stores with a auto parts dept.
If that doesn't help you are probably looking at replacing the whole fuse block.
You may not post new threads
You may not post replies
Forum Jump
how to adjust lowbeam headlight kathsstargazer General Maintenance 1 03-01-2010 11:27 PM
oem headlights built54 Items Wanted 2 12-31-2009 07:06 PM
G6 Headlights. Timmn1 General Maintenance 2 08-11-2009 12:13 AM
Fog in headlights Saclunch Problems and Solutions 3 08-19-2008 03:17 PM
© AutoGuide
