Grinding noise - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Pontiac G6 Forum > General Discussion > New Member Introductions
Thread Tools Display Modes
Old 03-06-2011, 08:25 AM   #1
mekb27
mekb27's Avatar
Gallery: 0
mekb27 is on a distinguished road
Grinding noise
So when i'm turnin my wheel after pulling out of a parking spot, i heard a grinding noise, it doesen't do it all the time. I also belive that i have a bad wheel bearing on the pass. side. Could the bearing also be the grind i'm hearing?
when i bought my GTP the owner said he hit a curb bad, and one of the rims is bent but still balanced. when i had the chance i took it in and had an alignment and i needed to replace the lower control arm. i still have a wobble on that side, but i only drive 5 miles to work and work 6 days a week so i haven't worried about b/c it's winter and i'm not driving any where.
Could i have more wrong since the aligment is good, and that it is pulling other parts that might be bent? (spindle, half shaft?)
Any thoughts would be a great help, thanks
__________________
Had a 07 GTP coupe, traded in for my GTI....
mekb27 is offline   Reply With Quote
Old 03-07-2011, 06:48 AM   #2
geewhiz
Lifetime Member
geewhiz's Avatar
Gallery: 9
geewhiz is on a distinguished road
If you haven't, you may need to take your G6 to a front-end specialist.
You should make a trip to an empty parking lot to try to duplicate the noise, or even better, try to find the sweet spot where the car makes the noise when you want.
You can try swapping the rear tire with the front too, this will eliminate the possibility that its the tire/rim.
geewhiz is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Transmission grinding. need help mike0513 Problems and Solutions 7 12-26-2010 08:50 AM
Need help with odd noise jpdepucci Problems and Solutions 5 04-10-2010 03:01 PM
Grinding noise with new brakes poveren Problems and Solutions 2 03-23-2010 04:02 AM
Wierd Noise Altami Problems and Solutions 6 11-17-2008 10:30 AM
AM Radio Noise uspakmnt Problems and Solutions 1 10-09-2008 07:02 PM
© AutoGuide
