how to replace your front bearing - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Ľ Wheel & Tire Center
Go Back   Pontiac G6 Forum > Technical Discussion & Modifications > HOW-TO
Thread Tools Display Modes
Old 04-18-2011, 02:15 PM   #1
clisto
Gallery: 0
clisto is on a distinguished road
Hi guys!!!
Here are the steps I took to replace a faulty front passenger hub bearing.
First of all, you will need the following.
13mm socket
14mm socket
17mm socket
36mm deep socket
3 jaw puller (to remove the hub bearing from the axle)
1/2 inch torque wrench that goes up to 160 ft/pounds
U joint extension
Short and medium socket extensions
1/2 breaker bar
New Hub bearing
After safely raising the car and removing the tire, spray some wd-40 or equivalent on the axle threads and nut. This is to clean the threads and help loosing up the nut.
Time to remove the axle nut; stick something in the rotor cooling holes to prevent it from rotating COUNTER clockwise. You may think that the parking gear on the tranny could hold the torque but why risk it. I recommend that you use a breaker bar. The nut size is 36mm.
After removing the nut, we can safely remove the caliper, caliper mounting bracket and the rotor. Be sure to prevent the caliper hang from the hose, be sure to secure it with some wire or tie wrap and tuck it out of the way.
Remove the 3 bolts securing the hub bearing to the knuckle. Be EXTREMELY careful not to damage the CV boot when doing this. The bolts are 13mm
After removing the 3 bolts, the brake shield will be loose and you can actually pull the bearing out of the knuckle. DONT HAMMER on the axle, instead work smartly and get a 2 or 3 (preferred) jaw puller. Be sure to add some lubricant to the spines to help the removal. Be sure to disconnect the ABS sensor from the knuckle before removing the bearing!!!!
Clean the knuckle for dirt and brake dust. I even a light coat of grease on the spines and on the mounting surface of the bearing to help in the install. Just a very light coat. If you overdo this, you will have grease all over the inside of the wheel and probably on the rotors. If in doubt, use some light oil.
Now time to install the new one....
Carefully snake the ABS connector thru the knuckle and axle, donít connect it yet. Align the brake shield with the holes and slide the new hub bearing. Screw the axle nut HAND TIGHT and screw the hub bearing bolts, again, be very careful when doing this!!
Also, notice that the bolts have some coloring to it. DONT REMOVE IT!!!
That is some sort or thread lock and a cool way of knowing which bolt goes.
Donít torque them yet.
Be sure that the axle is straight and there is no binding, then start torqueing the bolts in steps up to 85 ft/pounds, to prevent binding. I went from 25, 50 and final torque in a criss cross pattern.
DONT TIGHTEN THE AXLE NUT YET!!
Install the brake hardware then and only then you can torque the axle nut, AFTER securing the rotor from rotating CLOCKWISE, again to prevent strain on the tranny. Again, torque in steps. I went from 50 to 100 to 125 to 159 just to be sure.
Reconnect the ABS sensor cable and harness, if you have some dielectric grease, now itís a good time to add some at the connector seal to prevent moisture and water inside the connector and to ease removal in the future.... just in case.
Do a final torque check on all bolts, put the car in neutral and rotate the axle. Check the CV boots for damage, check the axle for binding and the ABS wire for rubbing. Mount the tire back if all clears ok.
Go and do some test drive!! Enjoy the sound of silence!!!
Total time, from raising the car to test drive 1.5 hours and that includes looking for the puller.
Skill, from 1 to 10, 10 being an expert, I will rate this a 5. If you can change your pads, you can do this.
As for if you purchase or rent the 36mm socket....well, you will need it if you need to work on the CV joint/boot so for 10 bucks I am sticking with it. It also makes an excellent paper weight at the office!!
Feel free to ask questions!!
Hope this helps those with noisy hub bearings!!
clisto is offline   Reply With Quote
Old 04-26-2011, 01:15 PM   #2
JRepasky
-Banned-
Gallery: 0
JRepasky is on a distinguished road
NO PRESS REQUIRED? +1 DOMESTICS!
Insightful, and appreciated.
Thank you for the information.
JRepasky is offline   Reply With Quote
Old 05-26-2011, 11:58 AM   #3
sprockett
Gallery: 0
sprockett is on a distinguished road
So, I have a 2005 G6 GT with ABS, but when I went to change my hub assembly there isn't a sensor as part of it? Why is that?
sprockett is offline   Reply With Quote
Old 05-26-2011, 08:49 PM   #4
Abyssul
Gallery: 0
Abyssul is on a distinguished road
No pictures?
__________________
Abyssul is offline   Reply With Quote
Old 11-20-2011, 07:05 PM   #5
badfish1111
Gallery: 0
badfish1111 is on a distinguished road
OK I just did this on my front passenger side. I did it pretty much exactly the way you have written down here but now my ABS light, traction control light and the light with the car and the wrench are all on. What made this happen? I installed them correctly as far as I know and the car drives a hundred times better, no noise or anything but why are these lights on now?
badfish1111 is offline   Reply With Quote
Old 12-27-2011, 09:21 AM   #6
VanBillSing
Gallery: 0
VanBillSing is on a distinguished road
Originally Posted by Abyssul View Post
No pictures?
Here's a
that I found pretty helpful when I changed mine.
VanBillSing is offline   Reply With Quote
Old 02-21-2012, 01:39 AM   #7
Devriesd
Devriesd's Avatar
Gallery: 1
Devriesd is on a distinguished road
Post
need to do this hope its as easy as it sounds.
__________________
Black 2005 Pontiac G6 GT:
Mods: uPAC-GM11B Aux Input, red painted calipers, Black Arrowhead overlays, and CRAB Intakes.
Orange 1971 Ford F-100 Sport Custom:
Completely Stock -302ci
Devriesd is offline   Reply With Quote
Old 02-21-2012, 07:21 PM   #8
geewhiz
Lifetime Member
geewhiz's Avatar
Gallery: 9
geewhiz is on a distinguished road
I need it done but I'm going to drop it off and let someone else get dirty.
I'll watch!
__________________
Mike
MODS;
None, if I want a faster car I'll buy one.
geewhiz is offline   Reply With Quote
Old 02-22-2012, 10:57 PM   #9
Devriesd
Devriesd's Avatar
Gallery: 1
Post Difficulty 5 out of 10
Done and done! It's quite easy to do, except when the hub assembly/bearing is fused to the metal piece it sits in. the jaw puller just pushed the axle out the back of the bearing and compressed the CV joint. I had to use a big hammer and get aggressive with it, also tried to chisel it out a bit. It finally came out in 2 pieces. But now my car is quiet.
Thanks for the write up!
__________________
Old 03-19-2012, 07:41 AM   #10
kercnat21
Gallery: 0
kercnat21 is on a distinguished road
excellent "how-to"!!
it really is as easy as it sounds
but...both bearings and sleeves were very corroded and seized, and took a big hammer and wd-40 and even a propane torch and just pounded the hell out of it until it was loose. then slowly worked them out, cleaned out the opening, slid new ones in, bolted them up, there we go! smooth ride (and no vibrations, sounds, grinding, etc.) thanks!
kercnat21 is offline   Reply With Quote
Old 03-24-2012, 11:01 AM   #11
ThreeDog
ThreeDog's Avatar
Gallery: 0
ThreeDog is on a distinguished road
I remember having to do mine and it was a pain to get it off. Didn't have the tools in the vid but I had a hammer and just started going at it. Eventually loosened for me and bang, it was done.
ThreeDog is offline   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Hub assembly/ bearing problems? FirexWhenxReady General Maintenance 14 06-19-2013 12:07 PM
Wheel Bearing or Hub? AGP5000 Problems and Solutions 7 01-15-2011 04:04 AM
Wheel Bearing kcsov6 Problems and Solutions 1 04-05-2010 03:50 AM
Wheel Bearing CP3 General Maintenance 0 06-01-2009 09:58 PM
Need G6 MT axles, intermediate shaft, bearing cbulen Items Wanted 5 08-21-2008 01:46 AM
© AutoGuide
