Service Tire Monitor - Reset procedure? - Pontiac G6 Forum
» Auto Insurance
» Featured Product
Wheel & Tire Center
Thread Tools Display Modes
Old 05-06-2011, 10:41 PM   #1
jdt141
Gallery: 0
jdt141 is on a distinguished road
Hi All,
I need to reset the TPMS on my wife's 08 G6. We do not have keyless entry, and the procedure for resetting the system in the owners manual says
TPMS Matching Process for Vehicles
without Remote Keyless Entry (RKE)
1. Set the parking brake.
2. Turn the ignition switch to ON/RUN with the
engine off.
3. Using the Driver Information Center (DIC), press
the INFO and Set/Reset buttons at the same time
for about one second. Then press and release
the INFO button until the TIRE LEARN? message
displays.
Sadly, the "Set/Reset" button is not found anywhere else in the owner's manual, and I tried combining with other buttons on the dash. Any thoughts?
jdt141 is offline   Reply With Quote
Old 05-07-2011, 08:55 PM   #2
jdt141
Gallery: 0
Smile
anyone??? anyone??? bueller???
Old 05-07-2011, 11:43 PM   #3
StLouisDave
Gallery: 0
StLouisDave is on a distinguished road
the 'set/reset' button is the bottom left button that is an arrow pointing left.
When I did mine I had to press the unlock and lock buttons at the same time with the key in the on position. horn chirped and your on you way
lets us know
__________________
David Hall - 2009 Pontiac G6 GT Blue 4-Door
Performance: CRABS 03 and FPU, Resonator Delete, RL Strut Tower Bar
Appearance: Debadged - Window Tint 35% front 18% back - Emblem Overlays - Door Sill Overlays
StLouisDave is offline   Reply With Quote
Old 05-08-2011, 09:59 AM   #4
SexyG6
Gallery: 0
SexyG6 is on a distinguished road
if its like the monsoon radio in my 08 GT and 09 GXP the "reset" button is the one used to set everything to zero (trip miles fuel econ avg mph etc) and is the button with the "enter arrow" on it
__________________
2008 Pontiac G6 GT Dark Gray Metalic
Bought Feb 28 2009 with 24k miles now has 130k miles RIP Baby death snowplow 1-30-11
http://www.g6ownersclub.com/forum/showthread.php?t=4757
Carbon Black Metalic 2009 G6 GXP Coupe
Bought Oct 8 2010 with 35 miles
Mods so far: every single performance mod and a whole lot more, fastest NA G6
http://www.g6ownersclub.com/forum/showthread.php?t=7974
1/4 mile: 13.17@ 109.23
Performance Red Metalic 2009 G6 GXP coupe
bought june 29 2012 with 3400 miles
Mods: RACE CAR- full race fuel setup and in the process of converting to RWD with a 6spd manual trans
http://www.g6ownersclub.com/forum/sh...ad.php?t=13140
1/4 mile: 14.20@ 101.95
SexyG6 is offline   Reply With Quote
Old 05-08-2011, 08:24 PM   #5
Kniggit
Gallery: 0
Kniggit is on a distinguished road
the arrow is the the return symbol from back when you had to return a typewriter's carriage..... not to get to far off topic. But most people now associate that with enter.
__________________
We are the knights of the round table, we dance when we are able.
Kniggit is offline   Reply With Quote
Old 05-05-2014, 09:28 PM   #6
elitewings
Gallery: 0
elitewings is on a distinguished road
INFO set/reset buttons tpms relearn
I tried everything including the set/res buttons on the steering wheel. Nothing seems to trigger my tire learn mode. I already went to the owners manual and it says to (step 3) press the INFO and Set/Reset buttons at the same time for about one second. Then press and release the INFO button until the TIRE LEARN? message displays.
step 4. Press and hold the Set/Reset DIC button for approximately three seconds to start ethe TPMS learn mode.
That 4th step is when the TIRE LEARN? message appears, but i cant get that message to come on. I have a 08 G6 2.4l i dont have the keyless fob entry so thats not an option. There has got to be a way. Any thoughts? Help is much appreciated.
elitewings is offline   Reply With Quote
Old 07-13-2014, 04:48 PM   #7
TheAlien
Gallery: 0
TheAlien is on a distinguished road
If you have remote keyless entry, press the lock and unlock buttons on your remote at the same time until your horn chirps twice. Then it's a fairly long process, but an easy one.
First: Make sure you're near a air compressor.
Second: After the horn chips, go to the driver's side front tire and press the valve stem to release air from the tire until the horn beeps. This could take anywhere from ten to thirty seconds.
Third: Repeat above step on the Passenger's side Front, then Passenger's side Rear, then Driver's side Rear, in that order. The horn should chirp twice again, this signifies the learning is complete.
Last step: Re-inflate your tires to the recommended pressure and then remove the keys.
I hope this helps
TheAlien is offline   Reply With Quote
Old 07-14-2014, 06:13 AM   #8
mshinall
mshinall's Avatar
Gallery: 24
mshinall is on a distinguished road
This process is really easy. Done it several times myself. Is pretty much a must after tire rotation. Another cool thing is that only the corner light for the tire you're checking is lit as you move around the car. Helps keep you in the right order.
Sent from AutoGuide.com App
__________________
2009 Techno Gray Metallic G6 GXP Sedan (3.6L Auto6 112K miles)
CRAB Intake Opt 3 w/FPU, Lloyds GXP floor mats, HIDs low 6000k 55w/fog 3000k 35w, LED DRLs behind lower grills, V3 Triton LED turn signal/reverse/brake, LED side markers/maps/dome/tag/trunk/high mount stop, 2 coats niteshades on tails, Tint 35% all around, Debadged (except arrows), PAC IPod and BT adapters, PowerStop D/S rotors and ceramic pads, Resonator repl w/24" cherry bomb, Racingline STB, Big 3 Upgrade, Optima Yellowtop D75/25, Blacked out arrows, chrome window trim and black dipped wheels, KYB struts and shocks, CM lowering springs, Cherry Bomb Vortex Crossflow muffler, 2.5" pipe from axle back, two 4" stainless double walled slant tips
...still working...
mshinall is offline   Reply With Quote
Old 08-22-2015, 06:49 PM   #9
PontiacG62008
Gallery: 0
PontiacG62008 is on a distinguished road
My car was fine but I took it to a local Pontiac dealership for a recall. Well one of my tire sensors were bad. So it read -- on the display. Well they checked it and then all said --. I replaced the broken one. I programmed them and it went fine but all still say -- .
What's the deal? How can I fix this myself?
PontiacG62008 is offline   Reply With Quote
Old 08-22-2015, 06:50 PM   #10
PontiacG62008
Gallery: 0
I used this instructions from my manual:
Click image for larger version
ID:	10633   Click image for larger version
Old 08-24-2015, 06:51 AM   #11
tireguy
tireguy's Avatar
Gallery: 0
tireguy is on a distinguished road
just take it to your local tire dealer and have them reset it, takes a matter of seconds
tireguy is offline   Reply With Quote
Old 08-24-2015, 01:57 PM   #12
PontiacG62008
Gallery: 0
I went to my local tire shop and they said they would reset them the same way I did. Any other ideas?
You may not post new threads
You may not post replies
Forum Jump
opps oil reset testertester811 General Maintenance 4 12-28-2012 07:49 AM
SVC Tire Monitor? Mr Funkhouser Handle It! - Suspension, Wheel and Tire Modifications 10 11-29-2011 08:10 PM
How to reset mpg monitor paramount Problems and Solutions 4 06-03-2010 12:26 PM
tire pressure monitor shows incorrect tire location rocr62 Problems and Solutions 3 01-06-2010 09:54 AM
Improve Throttle Response With the "Procedure" mjgonegm Powertrain Performance Modifications 22 06-30-2009 01:44 PM
© AutoGuide
