3.5 Running Lean With CRABS And GT-R - Pontiac G6 Forum
post #1 of 5 (permalink) Old 09-16-2011, 07:55 PM Thread Starter
coastiejoe's Avatar
I have a 07 GT vert and have had full CRABS since January and the GTR since about March. On my way to DC this past week, I had my check engine light come on. The guy at Sears said the code was for the engine running to lean. He said it could be a vacuum hose leak. I called my local mechanic and he said it was more than likely a result of the intake and exhaust moving more air and the fuel ratio staying the same. He recommended getting a tune (WAMS). Has anyone else had this problem and has the WAMS fixed it?
Thanks
2007 GT Convertible: Black Eagle Eye's with 6K HID; Tinted Tails; Tinted windows; 18" ENKEI EKM3 Gunmetal Rims; LED Bulbs All Around; MPD Ram Air Hood; CRAB Option 3 & 4; GT-R Exhaust System
coastiejoe is offline
post #2 of 5 (permalink) Old 09-16-2011, 10:03 PM
A tune should fix it, however first try a computer reset.
Disconnect your battery for 25-30 minutes and see if that fixes it.
06 GT - black on black
BORN2SKI is offline
post #3 of 5 (permalink) Old 09-18-2011, 07:23 PM
before you do anything else, check your intake, if there is a vaccum leak after the MAF sensor the car will run lean
2008 Pontiac G6 GT Dark Gray Metalic
Bought Feb 28 2009 with 24k miles now has 130k miles RIP Baby death snowplow 1-30-11
https://www.g6ownersclub.com/forum/showthread.php?t=4757
Carbon Black Metalic 2009 G6 GXP Coupe
Bought Oct 8 2010 with 35 miles
Mods so far: every single performance mod and a whole lot more, fastest NA G6
https://www.g6ownersclub.com/forum/showthread.php?t=7974
1/4 mile: [email protected] 109.23
Performance Red Metalic 2009 G6 GXP coupe
bought june 29 2012 with 3400 miles
Mods: RACE CAR- full race fuel setup and in the process of converting to RWD with a 6spd manual trans
https://www.g6ownersclub.com/forum/sh...ad.php?t=13140
1/4 mile: [email protected] 101.95
SexyG6 is offline
post #4 of 5 (permalink) Old 09-18-2011, 10:16 PM Thread Starter
coastiejoe's Avatar
Is there an easy way to check the vacuum lines or is that something that a shop would have to do?
post #5 of 5 (permalink) Old 09-18-2011, 10:59 PM
It also sounds like unmetered incoming air to me. The fuel trim system can compensate for any amount of incoming air but only if it's all metered.
A smoke machine test is the safe & easy way to find intake leaks but only shops have them. It's not very expensive to have done.
Of course, there's always the DIY propane method.
lean codes, traction control light, hard shifts??? chuxta1983 Problems and Solutions 5 11-26-2018 08:48 AM
Daytime Running Lights (DRL) kgovani40 Appearance Modifications and Lighting 4 05-04-2011 11:48 AM
What A/V setups are you running? RedRocket Car Audio, Video and Security 4 04-29-2011 06:35 AM
3500 Running too Cold Pikanjoe Problems and Solutions 0 03-09-2011 08:08 AM
Running new speaker wire Dragon12579 Car Audio, Video and Security 9 01-02-2010 04:44 PM
