2007 g6 needs brakes and rotor replacement - Pontiac G6 Forum
post #1 of 5 (permalink) Old 10-04-2011, 06:23 PM Thread Starter
I bought a 2007 g6 last july. Within less than 5k miles my rotors were warped and were changed before the car was sold to me. I went to napa and they told me they had two different sizes... I went with the 11.7 size rotors and put them on my car and started to hear scratching so I went back to napa and got the 10" size.. 9k miles later they warped.. so now, I'm puzzled... Can anyone tell me
A). Which size rotor is correct?
B). Which slotted and drilled rotors do I go with? (Because most likely I will end up buying those)
bgflower is offline
post #2 of 5 (permalink) Old 10-05-2011, 09:27 AM
Same size you originally replaced, look in your junk pile.
post #3 of 5 (permalink) Old 10-05-2011, 11:46 AM
http://stores.ebay.com/r1concepts
post #4 of 5 (permalink) Old 10-05-2011, 12:22 PM
Lifetime Member
geewhiz's Avatar
Do you wet the wheels (car wash) after you've been driving a while?
I ask because for years I couldn't understand why my rotors would warp so easily. Then I was told that wetting the rotors when they were hot would warp them just enough to create a "wobble" while braking. Now I avoid getting them wet from a car wash as often as possible, so far its working.
Mike
MODS;
geewhiz is offline
post #5 of 5 (permalink) Old 10-05-2011, 04:00 PM Thread Starter
No, I don't wet my wheels.. I think that they were just bad brakes/rotors on that car
bgflower is offline
Rotor/Brake Replacement '05 G6 nichwarzy General Maintenance 84 03-07-2019 02:31 PM
Rotor choosing Help aLienationz Problems and Solutions 3 05-14-2012 05:27 PM
2007 water pump replacement skidoomachzz Problems and Solutions 2 07-06-2011 12:51 PM
2007 Front Rotor Size UtilityRider51 General Maintenance 1 06-28-2011 07:19 PM
2007 G6 GT Caliper replacement pj4g6s Problems and Solutions 0 08-05-2010 09:08 AM
