Carpet behind drivers seat soaking wet every time it rains? - Pontiac G6 Forum
post #1 of 8 (permalink) Old 11-29-2011, 07:43 PM Thread Starter
We have a 2008 G6 GT coupe that we purchased used with about 30k on it, and amongst a few other issues that ive had to fix, im currently at this issue and can not find the solution. So recently it has been raining quite a bit, my girlfriend got out of the car, and took her purse off the floor behind the drivers seat and it was soaked, so i pulled the floor mat, soaked, and hung it to dry and dried up the left over water from the floor. I briefly looked for leaks but saw no signs of water coming in anywhere near it. A week or so went by, and it started raining again pretty hard, i looked to see if there was any signs of leaks this time, and there was a substantial amount of water on the floor behind the drivers seat again. I can not see any areas around the door that show signs of water leaking, or around the quarter window, rear window, etc. Has anyone else had this kind of problem before? I want to fix it before it gets that pungent wet/moldy smell. Any suggestions from someone that has dealt with a similar issue would be much appreciated. Thank you in advance.
SBRJoe is offline
post #2 of 8 (permalink) Old 11-29-2011, 07:57 PM
do you have a sunroof? if so sounds like the 'ol drain tubes. just search "drain tubes" on this forum and youll find the fix.
post #3 of 8 (permalink) Old 11-29-2011, 09:41 PM
attackofthegirt's Avatar
Ive had this same issue in my 2005 G6 GT. Sounds likewaterflower76 knows whats up
attackofthegirt is offline
post #4 of 8 (permalink) Old 11-30-2011, 04:15 PM Thread Starter
Yes, it does have a sunroof. I did some research and saw a few instances where the same thing was occurring, they said the same thing about the drain tubes. Thanks for the help. Looks like ill be calling the dealer to bitch again. Its like im calling every week since we got it, about a new stupid problem. I can fix it, i just dont feel like i should have to. Ugh.
SBRJoe is offline
post #5 of 8 (permalink) Old 11-30-2011, 05:35 PM
G6inCanada's Avatar
Hey, mine just started to do the same. My seatbelts were soaked yesterday! Im gunna see if the drain tubes are blocked. How would i blow them out? Or would they be blocked just at the sunroof. Obviously an air compressor could be used but could it damage anything?
Hammerhead Spoiler, CRAB intake, Resonator delete, Custom Magnaflow exhaust set up, Racing line front mount strut bar, Racingline MMI's, Red streetglow neon, WMAS 91 tune, 6000k HID's High's and Lows, Black and red outlined floor matts!
G6inCanada is offline
post #6 of 8 (permalink) Old 11-30-2011, 09:17 PM
The most common problem is that their so dam short they pull away from the coupler. You just need to re-connect them.
post #7 of 8 (permalink) Old 11-30-2011, 09:17 PM
Firedown's Avatar
They're probably not blocked. The drain tubes are really tubes, I think there's 3 of them connected end to end but they are way too short and can become disconnected.
Mods: GT-R exhaust, CRABs O3 w/FPU, 35% tint, 5000K HID lows/fogs, upper/lower recessed grilles, Racingline strut bar, concept darts, white LEDs everywhere
Firedown is offline
post #8 of 8 (permalink) Old 12-01-2011, 06:07 PM
G6inCanada's Avatar
So where do they run? At a place where i can get at them easily to reconnect them?
Long Time G6 Driver, First Time G6 Owner G6Whitie New Member Introductions 30 07-22-2011 04:36 PM
Right side of drivers seat seems broken Blackhawk131 Problems and Solutions 3 08-30-2010 03:04 PM
Carpet Fuzz12285 Appearance Modifications and Lighting 0 08-28-2010 04:44 PM
06 Gt Coupe - Drivers Seat Movement fbg6coupe Problems and Solutions 1 12-10-2008 11:12 AM
Looking for 2005 G6 Drivers Seat. 05G6V6 Items Wanted 2 08-07-2008 10:33 PM
