07' G6 Crankshaft sensor Location - Pontiac G6 Forum
post #1 of 3 (permalink) Old 12-08-2011, 03:11 PM Thread Starter
Hello all,
I have a 2007 Pontiac G6 with a 3.5l v6 in it i am confused to where the crankshaft sensor is anyone able to help me out here?
Also, after replacing the crank sensor do i have to get the ecm flashed?
Any insight on symptoms of a bad crank sensor would be appreciated.
thanks!
Ametz5 is offline
post #2 of 3 (permalink) Old 12-08-2011, 04:37 PM
What code/s are you getting? When I get back to my desk I'll send a pic.
post #3 of 3 (permalink) Old 12-08-2011, 10:28 PM
Originally Posted by Ametz5 View Post
Hello all,
thanks!
After replacement of the CKP sensor the CKP system variation learn procedure needs to be done using a tech 2.
On the 3.5l, its located on the firewall side of the block.
https://www.g6ownersclub.com/forum/at...1&d=1323408008
There's a how-to in the Chiltons for G6.
Without input from the CKP the car will crank but not start. The problem very often is with the harness.
need help removing crankshaft pulley from 3.5 2008 g6 kenjermain31 Problems and Solutions 4 09-07-2017 02:48 AM
Location of Engine Coolant Temperature Sensor? wait Problems and Solutions 8 01-17-2017 01:14 PM
3.6 engine with multiple crankshaft correlation codes nitrohogg Problems and Solutions 2 05-28-2011 08:10 AM
crank sensor location 07 3.6L babydollv76 Problems and Solutions 1 03-07-2011 07:10 PM
I need help with a crankshaft seal! Proper-T Problems and Solutions 6 05-26-2010 11:21 AM
