06 GTP Cold Air Intake check engine lights? - Pontiac G6 Forum
post #1 of 4 (permalink) Old 12-27-2011, 02:33 PM Thread Starter
hey everyone, I have a 2006 G6 GTP manual, just installed a cold air intake i ordered online. I installed last night and drove all day until now, and the check engine light just came on. I got the code read at autozone and they said Bank 1 and Bank 2 sensors are reading that the car is running too lean (too much air). It said right on the print out that they gave me that if they both are on at the same time it is most likely the mass flow sensor. I know that this isn't a coincidence and that it is obviously a result of installing the intake, I am working on re-installing the stock intake as we speak. My question is if i re-instal the stock system up until the airbox and just put the cone filter on instead of the box, would it keep throwing me the codes? I see that a lot of people on here have installed just the cone on the stock piping so I'm wondering if anyone else has ran into this issue. My next question is is anyone has had issues with the CRAB box (which I am quickly realizing is what I should have bought in the first place) throwing codes on the 3.9 liter engine. I plan on having an exhaust system installed this summer and really want an intake to be in place, so any help would be appreciated!!!
cswild26 is offline
post #2 of 4 (permalink) Old 12-28-2011, 01:57 PM
Varsity Squad
CalsGTP's Avatar
I have an 06 GTP 6spd also, and I have not had any problems with my intake causing lights to come on. I started with a cone filter attached on the end of the mass air flow w/ stock piping and then made a heat shield later. Now I have some piping from Auto Zone that I attached to the mass air flow and piped my cone filter into the front bumper after removing the air intake resonator. That is what I am still running. If you need a mass air flow sensor I have a brand new one that I thought I needed, but had a broken wire instead. I will give you a really good deal on it.
CalsGTP is offline
post #3 of 4 (permalink) Old 12-28-2011, 04:36 PM Thread Starter
Well I took the piping all out and put the stock plastic piping back in and just left the cone filter on the end of the MAF. The check engine light went off for now, I'm still confused as to how switching from plastic piping to metal made the light go on, maybe there was a leak somewhere that I overlooked. I'm just gonna leave it how it is for now and order the CRAB air box sometime in the next couple weeks. Guess I shouldnt have ordered an odd brand and just went with what worked for everyone else!
cswild26 is offline
post #4 of 4 (permalink) Old 12-29-2011, 05:19 PM
Varsity Squad
CalsGTP's Avatar
A life lesson learned.
CalsGTP is offline
Check Gas Cap messgae/Check Engine Light on Davidk Problems and Solutions 4 09-21-2012 11:53 AM
Seeing it everywhere - Cold Air Intake Waggs Powertrain Performance Modifications 11 07-03-2011 03:00 PM
Cold Air intake on my 2.4l kgovani40 Powertrain Performance Modifications 9 02-18-2011 09:58 AM
Cold air intake! DJB1209 Items Wanted 7 11-13-2010 08:26 AM
Check Engine/Scv Vehicle Soon/Reduced Engine Pwr Indicators all on? insiminator Problems and Solutions 7 09-19-2010 08:21 AM
