2006 pontiac g6 2.4l 105,000 miles p0449 and intermediate steering shaft issue - Pontiac G6 Forum
post #1 of 14 (permalink) Old 12-29-2011, 11:20 PM Thread Starter
Unhappy 2006 pontiac g6 2.4l 105,000 miles p0449 and intermediate steering shaft issue
I have g6 throwing the code p0449 and im trying to look for the part for my evap vent solenoid. I know it is attached to the gas tank but im not sure how the part is listed... Do I need Canister Vent Valve or Canister Purge Solenoid? I do know that there is nothing wrong with my Canister Purge Solenoid that is on the top of my engine.
My second issue is my intermediate steering shaft. I have had it replace and all the dealer did was replace it with refurb part. So now my issue is I want to just lube it up. I found a picture on one of these forums how to lube it but it is difficult to get lube in the spot shown in picture. http://www.justanswer.com/pontiac/2o...bought-it.html
i also have vibration in the steering wheel....example would be when im drive down the road and I let go of steering wheel it will shake back and forth?
(ive changed brakes rotars, had alignment and balance)
Any Ideas
ncdavid2001 is offline
post #2 of 14 (permalink) Old 01-04-2012, 03:00 PM
master cyliner
wheat67 is offline
post #3 of 14 (permalink) Old 01-04-2012, 04:08 PM
The 449 means you have a bad vent solenoid valve or a problem in it's wiring harness. If you PM me with an email address I'll send the vent valve R&R from the '06 manual. You'll have to partially drop the fuel tank.
post #4 of 14 (permalink) Old 01-05-2012, 09:20 AM
Easy to lube shaft, no panels to remove.
post #5 of 14 (permalink) Old 01-08-2012, 09:02 AM Thread Starter
greenman my email is [email protected]
Master Cylinder? What does that have to do with the problems I listed
And I have tried lubing the shaft but white lithum grease foams up and really doesnt go in the shaft....and I now have new problem. A hissing noise when im accelerating. I dont know if it is from steering or what its from it sounds like it is right in front of me while im driving. It sounds like its pressurized
post #6 of 14 (permalink) Old 01-08-2012, 09:38 AM
WD40, PB Blaster, it works. Hissing noise, if more like whistle, resonator, common problem.
post #7 of 14 (permalink) Old 01-08-2012, 12:01 PM
The new I-shafts are not supposed to be lubed.
"Important: Revised design intermediate shafts went into production in the 2009 model year and are the only design currently available through GMSPO since approximately September 2008. Since any model year vehicle could have had a second design shaft installed, it is critical to identify it before proceeding. The revised design intermediate shafts will NOT tolerate any type of lubricant per the following instructions. Adding lube to the second design shafts will cause a clunk noise in a very short period of time. Use the following pictures to identify which design of shaft you are servicing."
post #8 of 14 (permalink) Old 01-09-2012, 09:22 AM
If the revised IS won't clunk, why would anyone lube it.
post #9 of 14 (permalink) Old 01-09-2012, 10:12 PM Thread Starter
Today I tried to drop gas tank and I couldn't get the fuel tank guard or whatever past my exhaust pipe. What is the trick to get the fuel tank guard past exhaust pipe so I can lower gas tank enough to reach my hand up to change part?
post #10 of 14 (permalink) Old 01-09-2012, 10:13 PM Thread Starter
And I have the old i/s shaft I can lube it.it is just hard to get lube in spot
post #11 of 14 (permalink) Old 01-09-2012, 11:11 PM
Oh, but the new shafts do clunk. You didn't think GM would design out that popular feature did you?
post #12 of 14 (permalink) Old 01-10-2012, 09:16 AM
The exhaust is in rubber mounts, just pop out enough to get tank down.
post #13 of 14 (permalink) Old 01-10-2012, 09:18 AM
lol
post #14 of 14 (permalink) Old 01-10-2012, 10:43 PM Thread Starter
What about the muffler in the rear. That seems like what is holding the exhaust from moving. It is actually.mounted the pipe is not
Intermediate Steering Shaft Lower Pinch Bolt je1279 Problems and Solutions 1 11-06-2011 01:41 PM
Is this a bad intermediate shaft? Boostaddict-g6 Problems and Solutions 10 12-20-2009 02:43 PM
intermediate shaft / Cv shaft dbritner Problems and Solutions 17 12-18-2009 06:59 PM
2006 G6 Intermediate Shaft dankoos Problems and Solutions 1 12-18-2009 06:57 PM
steering: intermediate shaft 08G63.5 Problems and Solutions 1 12-18-2009 11:20 AM
